funtanaX50
MO
I am needing a home for my pro 46 an wanting a good flyer my landing strip at 1 end to the tree line is about 300 ft right now i'm flying a sse there but am ready to move up I need a plane that has a strong landing gear setup
Banned
The funtanaX50 is a great plane but just like any 3D plane the landing gear is weak. If you still want it I would beef up the landing gear. Also the .46 is not going to be able to pull out of a hover well.
OK
You will be lucky if the TT pro 46 will pull it out of a hover at all. I had a giles that weighed less than the Funtana X and it would just barely pull out of a hover with the TT pro 46 So I usualy just flew out of the hover when I was through hovering. I had a magnum .52 2-stroke that would power a plane like the funtana probibly better than any .46 class engine. You might take a look at the magnum it was a very nice engine.
wasn't he just said he have motor and look for a plane for it ??
so I guess he won't buy and not looking to buy new airplane and new motor, right?
Try to look for profiles suite for 46 size motors, they are the best flyers,
and actually any 46 size full fuse I know won't fly good with a 46 motor and needs more power...
check out the OMP guys for profiles avaiable..
MO
Thanks for all the info guy's like i said i need a good home for my pro 46 an i need to be able to bring her over the trees that are 300 ft from the start of my run way an these are some mighty tall trees ie big locust trees i put a telemaster in on an had to have the local light company take it out cause you sure can't climb a locust tree Thorns my sse just barlely doses it I know i can knife edge it an then roll her back level an bring her in I love my se but i am ready to move up an am not wanting to buy another motor although i do have a 90 surpass that is sitting around but she is not dependable enough to fly here at home I'd have to go to a club site an the nearest 1 is 30 miles away
