Nitroplanes Extra 330L 50 size.
AR
I have recently purchased the new Extra 330L 50 size (blue). This airplane was very impressive on the construction. The plane calls for a .46 size engine, I will be using a OS .61 AX on it. I have not completed the plane yet. I can't wait to fly it. the plane was packaged very well and the plane itself looks very good. If anyone has this plane please post how it flies. I don't want any surprises with this one. I have recently purchased the new Extra 330L 50 size. This airplane was very impressive on the construction. The plane calls for a .46 size engine, I will be using a OS .61 AX on it. I have not completed the plane yet. I can't wait to fly it. the plane was packaged very well and the plane itself looks very good. If anyone has this plane please post how it flies. I dont want any suprises with this one.
AR
I did mean OS 61 I don't know why I put AX. Sorry[&:]. This engine makes it scary fast. I am using a 12x8 prop. I used all the hardware that came with the ARF, the hardware isn't that bad. I finished the airplane today and was able to test fly it. All I can say is WOW!
. The plane was extremely responsive and fast. it is well built with a fiberglass fuselage,, The fuselage is a wide body with plenty of room to work with.
I only got to fly it 1 time just to trim it out. The one thing I did notice was it was tail heavy at the recommended CG's, I had a hard time landing it. You do not need allot of throw for this plane either. I will give you guys a full update along with some pics very soon. A buddy of my, will video me flying it soon. I can tell you this for sure this plane should be able to do some 3D maneuvers. It has got large control surfaces and it is not that heavy. I haven't weighed it yet but im guessing 5 lbs to 6lbs flying weight
. The plane was extremely responsive and fast. it is well built with a fiberglass fuselage,, The fuselage is a wide body with plenty of room to work with. I only got to fly it 1 time just to trim it out. The one thing I did notice was it was tail heavy at the recommended CG's, I had a hard time landing it. You do not need allot of throw for this plane either. I will give you guys a full update along with some pics very soon. A buddy of my, will video me flying it soon. I can tell you this for sure this plane should be able to do some 3D maneuvers. It has got large control surfaces and it is not that heavy. I haven't weighed it yet but im guessing 5 lbs to 6lbs flying weight
