sugestions for pull pull rudder mod in cap232 >
Old 01-30-2003 | 12:31 AM
Default sugestions for pull pull rudder mod in cap232
I bought this cap 232 http://www.giantscaleplanes.com/Cap232_66build.htm
and was talking down at the field and the guys suggested making the rudder pull pull, has anyone got some pics of a plane simular they have done this to.
I just need some ideas to kick me of with.....
Old 01-30-2003 | 02:58 AM
My Feedback: (12)
Default Pull Pull rudder
Check the Nelson website
http://www.nelsonhobby.com/
Not only good products but illustrations too. Choose one that uses cables off a wheel ( the cables cross to exit the fuse). JR at one time did these also however I don't see them now at the Horizon site. You might check there also.
EXCAP232
Old 01-30-2003 | 08:02 AM
You can also use a setup like www.swbmfg.com offers. They have the trays, horns and other accessories.
Old 01-31-2003 | 05:12 AM
Default Re: sugestions for pull pull rudder mod in cap232
Originally posted by Dogz
I bought this cap 232 and was talking down at the field and the guys suggested making the rudder pull pull, has anyone got some pics of a plane simular they have done this to.
First off do you NEED to go to a pull-pull? Keep in mind one of the main reasons for going pull-pull or servos in the tail is balance. My suggestion would be to buld the plane and install EVERYTHING but the rudder servo and then decide what you need to do for balance.
I listed to someone's suggestion once only to have to change to a pull-pull to correct for a tail heavy plane.
Best of luck.......Mark
Old 01-31-2003 | 05:15 AM
I think I'll stick to the plans and see who the plane runs...
i thought with the rudder servo mounted on the rear as per the plans changing it to a pull pull would be easy..
