I Need To Smoke!!! >
I Need To Smoke!!!
I Need To Smoke!!!
Old 02-12-2003 | 11:17 PM
Default I Need To Smoke!!!
What would be the best smoke producing system for a 0S 160? Of course I'm looking for lightweight and in-expensive!!
Thanks for your time!!
Old 02-13-2003 | 03:23 AM
shanes300's Avatar
My Feedback: (8)
Default Smoke
A TME smoke system with a slimline smoke muffler and a 600 mah battery pack will do graet. I use a mixture of 50/50 disel and wd40 with a couple oz. of 2 stroke out board oil....Smokes like a pine knot....
I have this set up on a os 91fx on a Goldberg Extra....does fine...
Old 02-13-2003 | 02:21 PM
My Feedback: (31)
nicethumbs2:
I think i will follow you and smoke one or both of my OS-160!
Old 02-14-2003 | 09:44 PM
tonyc's Avatar
Shane is using the same set up I used. It does work very well.
Shane is wd 40 a mixture of Kerosene and oil? I think I read this some where. What does your method cost to mix per gallon?
I use to buy regular smoke fluid by the gallon. Makes you want to quit smoking, which I did.
I intend to start up again. You know you can never kick the habit.
tonyc
Shane: just noticed that you are in my back yard. I fly in Ruston.
