POst a picture of your 3d airplane
#78
Thanks Guys,
It is (I mean was) a cool littly toy. There are a few different (cheap GWS, not brushless) power setups and a report as well as plans on the link below. The only downide with it (in my vertion anyway) is that it does not fly well inverted you can do inverted low curcuits but it is not much fun. It does do great rudder turns almost on the spot!
http://www.rcgroups.com/forums/showt...threadid=89485
______________________________
The designer of ther edge has another design called a 3Demon that looks even better, it's kinda a Pattern/3D plane. Not yet flown though. Heres the link:
http://www.rcgroups.com/forums/showt...ghlight=3demon
There are many others just look roung the Ezone in foamys section, Parkflyers, Sports planes and Indoor.
http://www.rcgroups.com/forums/forum...p?s=&forumid=4
Hope that helps you guys.
Alan
Alan
#79
heres my latest, its a 1/3 scale Ultimate with a zenoah 45 swinging a 22 X 8 menz prop. 14 Lbs. Unlimited vertical.
#80
KY
Alan, thanks for the great info. I just blew an hour of my morning reading only part of that thread....now I'll be late for work. Oh well....I'm the boss anyway.
Gator......did you see this stuff?
#81
Glad to have helped TailSpnr,
Oh, everyone going on the first link watch out, its long.
But if you go into the indoor section on the Ezone, its no where near as long as the "Ultimate indoor 3D" thread which would take days to read (no really it would)! That one is about a delta plane which apparently flys very well and prophangs in you living room.
Alan
Alan
#84
Extra 300S
And my Extra 300S, electric powerd also, great flyer, and 3D is possible.
http://w1.158.telia.com/~u15807174/
#86
#88
Here is mine...
This is my scratch-built 80" Somethin' Extra. It took me a year to build it - I used a lot of carbon fiber to keep it light. All up weight is 13 pounds!
It's powered by a Saito 180 with a Perry pump. To me, being able to fly 3D means flying SLOW. And this plane will fly VERY slow. In a slight breeze I can fly it slower than my GWS Tiger Moth
Take-Off roll is about 15 feet and it'll climb verticle on 1/3 throttle. It does great waterfalls, flat spins, walls, torque rolls, elevators (wings rock a bit, though), Harrier landings and tumbles. I haven't had the nerve to try a Blender yet - I think something might break
#89
My Feedback: (31)
NV
LASER 3D W/ TIGER SHARK 52-12X4APC
HERE'S MY LASER WITH THE TIGER SHARK 52....THIS ENGINE IS REALLY RELIABLE AND HAS NEVER QUIT YET. THIS PLANE HOVERS JUST OVER HALF THROTTLE. RIGHT AT 5LBS.
#92
OH
this is my Ohio Model Plane's Profile Edge 540. This plane is amazing to say the least. I flew UCD's, Something extra's, Flips, Pizzazz's, Magic and Magic Xtra's and they fall far short of this plane. It weighs in at 3 pounds 9 ounces and is powered by a Pico 45. it has a 44" wingspan and over 700 sq. in. of wing area, plus it has 5 1/2 in wide ailerons taht taper to 4 inches. about 7 inches wide of rudder at the widest part and about 5 1/2 inches of elevator. I tried and tried to hover with alot of other planes and had NO LUCK. on my first flight I was doing 2 full torgue rolls and hovers at 1/4 throttle or less with the 12.25 X 3.75 prop. Check out the site http://www.ohiomodelplanes.com He has several mpegs to watch and it is a great plane. It is a kit though with a built up fuse and everything hidden other than the two servos in the rear.
SWEET plane.
Paulbo
SWEET plane.
Paulbo
#94
My Feedback: (12)
Not your average FLIP
Here is a picture of my Kyosho Flip 3-D, done in my own scheme.
Look here for more pictures.
http://www.rcuniverse.com/showthread...156#post855325]
#96
WV
For some reason I have a problem loading the fifth page of this thread. Well at least the images of the planes? Every time I try to load it my computer hangs up for a long time and the pictures never load. Somthing must have been posted that is causing my PC to get funky. Anyone else have this problem?
#97
My Feedback: (8)
I have the same problem...I can right click on the photo link, save to my hard drive and view the pics that way, but they (and the thumbnails) do not load...
Mark
Mark
#98
WV
Cool. I was beginning to think I had screwed spmething up. Wonder what the deal is?
Mark
Mark
#99
My Feedback: (12)
Me also
The page seems to load through post # 88, then everything else is hung. Then I continue to be unable to display objects and pictures on other threads until I log out, clear my cache, then log back in. It was not doing this before I loaded my image of the Flip yesterday. I tried deleting the image, but it still did it without my image on the page. My same image loads fine in another thread (the one referenced). I am sending this to the administrator for investigation.
