 switch blade cg >
switch blade cg
switch blade cg
Old 03-11-2007 | 08:46 AM
Default switch blade cg
i bought a switch blade airplane arf new in a box..made by league model co. the directions do not give a cg point!!!any clues..thax for any help
Old 03-12-2007 | 09:15 AM
Default RE: switch blade cg
Start with it on the spar, you're almost always safe there.
FWIW, I had one of those and it was a horrible plane. The only way I could get it to balance without lead was to slap a Saito 91 on the nose. I fought thrust line issues with it enlessly until I scrapped it.
Godd luck with yours.
P.S. That thin fuse is VERY fragile.
Old 03-12-2007 | 12:36 PM
My Feedback: (10)
Check out the review:
http://the******************.com/scg...l&n=1111632815
Old 03-12-2007 | 02:15 PM
perfect!!!! thank you!!!
