UCanDo 3D Prop Size With .55 AX
OR
What size prop would you recommend for 3d flying with a .55 AX motor on a UCanDo (size 46)? O.S's website recommends a 12-7 to 12-8 or 13-6 to 13-7. Based on this I speculated that a 14-4 or 14-5 would work best and was under the impression that with a two stroke I wanted to stray away from a wide blade prop. Is this true? What would be your recommendations?
Thanks in advance,
Michael
Thanks in advance,
Michael
OR
Do you think a 14-4w would be too much? I assumed it would have no more load than the recommended 13-7, is that wrong?
Michael
Michael
You could try the 14x4 just to see what it does. The 13x4 on mine will take my OMP Edge-540 straight up until it's almost out of sight and hovers are great too.
