help with U can do 3D 60
hi all, i am having a little bit of trouble with my u can do 3d. It has a Supertigre 75 two stroke flying a 13X6 prop. I can get it to hover but it will not pull out or anything. I am going to put a Supertigre 90 two stroke on it and im thinking a 14X4 wooden or apc, or a 15X4 wood or apc. The plane weights little over 7lbs dry. Do you think this is a good plane engine combo? how do you think the pull out will be?
My Feedback: (19)
For the ST 75 try an APC 13x4w.
For the ST 90 an APC 15x4w works great.
Here's two videos of my UCD 60 powered by a ST 90 with an APC 15x4w.
NOTE: you will have to replace the **** with the****************** dot com
http://the******************.com/~vi...0mcddd%201.wmv
http://the******************.com/~vi...0mcddd%202.wmv
I think the G90 stock would not be enough power for that plane. But with a quiet tuned pipe it would be enough pull for that plane and a APC 15x4w or 15x6.
If you like to stay twostroke I would look at the OS120AX instead. Suitable fourstrokes are Saito 125 or YS 110.
well i just won this motor and it used to have a G75 on it so i really dont want to go buy another motor to put in it. plus i have no money to purchase a new and bigger motor for it. thanks for the help.
My Feedback: (19)
The mousse can muffler (MCM) adds about 1000 rpm over the stock muffler on the 15x4w prop.
To build a MCM you'll need to buy a Macs header and get ahold of an aluminum can that measures 2" diameter and 10" long.
For instructions on how to build a MCM, go here:
http://webpages.charter.net/rcfu/
Look under the CONSTRUCTION link for the Mousse Can Muffler building instructions.
