Saito 150 and 18x8 prop, need help!
I recently flew my Funtana 90 with a 150 Saito in it for the first time the other day, and I love the motor so far. I only have one issue with it. I can hover the plane at about half throttle with a 18x8 prop, but if I try to give it anything more than that it won't pull out of the hover. I don't think I am under or over propped, so I am not sure why I don't get any more after half throttle. I bought a tach yesterday and this weekend I will figure out my rpm's.
I am running 15% nitro in it.
Could this be a prop issue?
Thanks in advance for any help!
Lilone,
18x6W or 18x4W will do it. Any more pitch than that and your in high gear. Try to get a 18x4W if you can. The less the pitch the lower the gear just like in a vehicle. What your doing with the 18x8 is like trying to start out in a car in 5th gear. Doesn't work well does it?
JMHO,
Gibbs
JMHO,
Gibbs
Lilone,
It means Wide. Just ask for one at you LHS or look for it on Tower Hobbies. They have a huge selection of APC props. That is where I get my wide props. Wide also will act as a break for landing by slowing the plane as it comes down. It will also change your takeoff role a lot. You will take off much sooner.
Gibbs
Gibbs
