Robart hinges >
Robart hinges
Robart hinges
Old 03-15-2003 | 10:20 PM
Default Robart hinges
Hi guys
What is the best clue for robart hinges?????
Old 03-15-2003 | 11:21 PM
MHawker's Avatar
My Feedback: (16)
I use Epoxy... Especially in foam wings, etc. Do NOT use CA in foam. It eats it away.
Just remember to have enough material for the hinge to go into.... even if you need to glue a block behind the surface.
Mike
Old 03-16-2003 | 11:54 PM
You could also use pro bond (or any other poly-based adhesive). I've found its foaming qualities effectively surround the barbs of the hinge and fills any voids in the foam. Coat the pivot point with vasoline to avoid glue seepage and tape the hinges down so the drying glue doesn't push them out. I fill the hole with the glue then dip the hinge in water before inserting it into the surface (pro-bond takes on water as it dries). I've never had a problem!
