angel s50e
I sent an email to Sebart asking them if they were going to release a glow conversion like they have with the katana. Their answer was no, but i don't see why you couldn't fashion your own conversion with some lite ply.
They sent me a heap of pics of installation steps for the katana conversion. You could use those as a rough guide on how to make a set for the Angel.
No! Stick with the 55ax, it is a POWERHOUSE when set up right. I had one in my Funtana X50 and @ 5.7-.8 lbs empty it would pull out of sight in a hurry! Do not worry about the wingspan, worry about the weight and if the add is right it comes in @ 4.8 or so electric (this is without the battery according to the video, so maybe about 5.5-5.7 glow would be my estimate). A Fliton Inspire also has about the same span.
If you run the 55ax order a Tower 46 muffler ($15) and use either an APC 12.25x3.75 or 13x4w and something like Morgan Omega 15%-25%. Before my unfortunate midair two weeks ago the 55ax on my Funtana was turning 14,400 with the 12.25x3.75 on 15%, I never even tached it with the 25%, but it really pulls hard with it. Hovered at half throttle and had balls when it was time to bail....
By the way, how much does it work out to be in $ and where can you find them? I still need to replace my Funtana.
