h9 cap,satio 180 ? >
h9 cap,satio 180 ?
h9 cap,satio 180 ?
Old 03-27-2003 | 05:31 AM
Default h9 cap,satio 180 ?
i have just received a h9 cap 232. i am going to put a satio 180 on it. what kind of performance can i expect with this combo? will it hover? if so what prop recomendation and fuel. anything you can tell me about this plane would be appreciated. thanks!!
Old 03-27-2003 | 05:39 AM
My Feedback: (14)
Great Combo !
YS 20/20 Fuel runs nice. You can run 30% heli fuel if you like $$.
Prop it with an APC 18x6W
Old 03-28-2003 | 09:38 PM
Awesome combo you will love it!
Old 04-01-2003 | 02:22 PM
I'll assume it's the 1/4 scale (74") Cap, not the 80"?
This is a great combo, you will love it.
Keep it light! don't dump a lot of extra equipment in it. Get the carbon fiber gear, thin walled spinner, 5 servo's with a "Y" or bellcrank on elevator, throw away the wheel pants, single battery pack, small screws.....
The wing dowel mounts tend to open up, double them up with some light ply oriented 90 degrees.
Throw away the Sullivan metal control horns (with the poly inserts), they wear and create slop in the linkage. Replace them with Robart nylon.
You may want to glue some triange stock to the back of your firewall, or glass it. If you do a lot of 3D the firewall can fracture at the side and come loose/off. This has happened to me twice but that was with a lot of hours on the airframes.
Check your incidences and washout/wash-in with a digital meter. One of mine came out of the box with +2 in one wingtip and -1.5 in the other. The plane rocked like crazy in the elevators, when I reset the incidences it smoothed right out. It should be tail=0, wing=0, motor 2 deg. up and 3 deg. right, 0 deg. of washout.
I've used spoileron/flaperon mixes for harriers and elevators but if it's light enough it doesn't need it.
If you can keep it at 11 pounds with fuel this combo will out perform almost anything twice as expensive.
Do a search for Hangar 9 Cap and you'll find lots of great threads on this one. Lots of guys (and moderators too) have been permanently warped by this plane. We usually end up buying lots of Cap models trying to find other verions that fly as well.
Chris
Old 04-02-2003 | 02:02 AM
thnx chris for the info, i never would have thought it needed 2' on the motor. if u know where i can get the composite gear i will definately pick some up. 1 more ?, i am thinking of putting the tank on the cg. do u reccomend this. i am worried if the satio will suck good from that far back.. thanku Kevin
Old 04-02-2003 | 12:59 PM
Kevin,
Cap's generally need up thrust due to the high thrust line and low center of drag. That's why when you come off on the power on landing they balloon. You'll have to fine tune it but 2deg up is usually the rule.
Troy built models sells the gear, they're nice.
Putting the tank on the cg is an excellent way to go. I opened up my formers and slid the tank back to the servo's. Use a Perry pump or a Cline regulator and you'll be golden. Don't try to do it on venturi suction alone.
This is a great combo, let us know when you get it flying and what you think.
Chris
Old 04-10-2003 | 07:22 AM
ttt
