H9 EDGE 540 Engine Offsets
Hi Guys,
Does anyone here know the Right Thrust and Down angles for the firewall on the Hangar 9 Edge 540?
As far as i know they're built in, but i also know that theyre quite a bit out.
I have seen figures on here b4 so you should get some feedback.
Thanks so much Nathan. Did you decide on which aerobat you will buy this year? I will be installing the new ZDZ 50 on the H9 Edge 540 so I have to build a motor box for it. I have check the offsets and came up with 2 degrees right thrust and 0 degrees down thrust. I would have really like to get a conformation of this form some of the other guys who probably did the same modification before going ahead. So I am hoping to get some responcses.
Do you still have your Edge?
Yes I still have the Edge, and I have just ordered a conversion kit for the engine... Instead of gas I will chabnge it to glow and achieve approx 1300RPM extra, plus lose over 1/2 lb in airframe weight. Hopefully 11.5lb with a little work.I think mine needs approx 2 degrees of right thrust
I bought a Funtana, and YS 140, gonna pick up 5 8411 servos in Orlando in a few weeks.
Here's a pic of her finished!
Should be flying in just over a month.
Nathan.
www.3drc.info
Nathan.
www.3drc.info
