Hangar 9 1/4 Cap 232 prop question >
Old 04-17-2003 | 03:12 AM
Default Hangar 9 1/4 Cap 232 prop question
Whats a good prop to hover/TR with on this plane. I was told 17x6 is that good. thanks
-Jordan
Old 04-17-2003 | 03:19 AM
CAP232CM's Avatar
My Feedback: (8)
You didn't tell us what motor your running.
Old 04-17-2003 | 03:52 AM
Sorry about that. I just bought it used and it came with a webra 120. I dont know if it will be able to TR or not, but its worth the try. I wanna get a used 140-160 for it sometime soon. I dont got the money for a new one.
-jordan
Old 04-19-2003 | 03:16 AM
h82crash's Avatar
It's not just the size but the airfoil, too. Don't expect much thrust from an APC. I would try a MAS wood if you're on a budget, or a top flight wood. Stay away from scimitar and pro zinger, They are more for speed and don't have as much thrust as the wide blade props. People will say " that prop runs slower or bogs my engine down" it's not just more drag that is loading the engine, it's grabbing more air and pushing a higher volume of air. The 120 may be too small to hover. When you can, go for an OS 160 and pump it and run a Mezjlik 18x8. You'll have a rocket.
