 Magic Hand 73" yak build thread >
Old 06-01-2008 | 08:57 PM
  #76
Default RE: Magic Hand 73" yak build thread
I had been looking forward to reading about the maiden flight, but thats not the outcome that I was hoping for,you either I'm sure.I'm sorry it didnt go better than it did.hopefully it's fixed up soon and ready to go again.If it is any consolation we had three Cubs go down today at my clubs flying field, none of which were mine but still a bad day none the less.
Old 06-05-2008 | 12:57 AM
  #77
Jeff, OOPS! LOL Well it looked great on the field! Sorry about the deadstick. Sounds like a quick fix though.
I've ordered the 25% Yak from East RC. It comes with carbor fiber gear and wing tube as well as free shipping. I didn't like the fact that TBM was advertising their plane for 229 and the price on their website was a hundred or so dollars more. I know they raised it back in April but continued to advertise even into this months (June) edition of Model Aviation. I didn't even bother to call them on it, just went somewhere else. Its a shame because that is a really good looking bird!! I'm just stubborn I guess. I'll keep checking back here for more flight reports. I've enjoyed following your thread.
Old 06-05-2008 | 04:05 AM
  #78
maineflyer's Avatar
My Feedback: (44)
Plowboy,
let me know how the East RC plane goes. Do you have a link for it? I have fixed the gear already and will build a new fire wall soon. The one that was on the plane was light and I think by it failing easily it actually saved other componants of the plane.
Jeff
Old 06-08-2008 | 12:05 PM
  #79
Well guys i've been following this thread since it started....... I've got the 25% also maiden flight was 6/7/08 went awesome...... I am running 645 all servos except throtle servos is standard, power plant is a 45cc ftl 20-10 prop, 7.4 2600mah lith lion with 6 volt regulator, running ignition is 4.8 2500 mah bcma I set my cg at factory 142mm She flyies like a charm got three flights in today 6/8/08 engine is on third tank of gas. plenty of power can hover at just under 1/2 power and verticle is unlimited.... I would recommend this plane to anyone great looking bird Landing this bird is nice and gentle Can't beat this set up for $800.00 Now i'm ready to start my 30% yak 55 sp that i've had sitting around for 5 months!!!!!!!!!!!
Maineflyer sorry about what happened hope you get it back in the air soon thanks for the build thead you did a great job!!!!!!
Old 06-08-2008 | 04:29 PM
  #80
maineflyer's Avatar
My Feedback: (44)
I cut a new fire wall and it's glueing up as I write this. The gear and throttle servo are both back in and the only thing left is to mount the engine and to get a new cowl. I want to have the plane back in the air by the end of the month. glad your maiden went well. How much did your plane weigh?
Jeff
Old 06-08-2008 | 06:05 PM
  #81
i haven't even weighted it yet but going flying agian tommorrow so i'll see what it is while at the fly field !!!!!!!!!
Old 06-08-2008 | 07:57 PM
  #82
I'm real glad your maiden went well.I have just got started assembly and will be using an os max 160.I usually start assembly by adding glue to the firewall, motor mount, landing gear mount and other stress taking areas on most of my arfs but this one looks pretty good to start with.has anyone else felt the need to reinforce these areas or go just go with it as it is?also I'm curious to know how it performs with an os 160 as opposed to running a saito 180 or a gas engine.any info would be helpful. thanks .Lance F.
Old 06-08-2008 | 10:05 PM
  #83
I did reinforce my fire wall a little other than that hit a few glue joints ....... I live in jacksonville,fl .....at the field we have several gasser planks,alot of few fly buddies have looked over the plank and really liked the look and build quality so far i'm pleased. Good luck with yours! I got the blue checker scheme
Old 06-09-2008 | 09:07 PM
  #84
Jeff, sounds like you are well on your way to recovery. I'm still waiting for my YAK to get here. Should arrive tomorrow. Did you figure out what happened yet? Sounds to me like classic low end richness!![&:]
Here is a link to the YAK I went with. I'm sure you've seen it before as other companies sell it, just without the carbon fiber upgrades.
http://www.eastrc.org/shop.cgi/page=...09446384.20838
I'll let you know my impressions when it gets here. So whats up with the EF YAK? Is she flying yet?
Old 06-09-2008 | 09:45 PM
  #85
I live near EastRc and did contact them about their 25%Yak.They said they could'nt really tell me who the manufacturer was but they thought is was a CMP (China Model Productions) built plane from the same factory that builds alot of different manufacturers planes.I saw on NitroModels.com web site a 25% CMP Yak and except for the carbon fiber looked to be the same plane.I am curious to hear what you think about it once you have had a chance to check it out.
Old 06-10-2008 | 06:38 AM
  #86
maineflyer's Avatar
My Feedback: (44)
Plowboy,
It was nothing to do with the engine just the lack of a glow plug that caused the flame out. Evidently it came loose during my final construction and I failed to retighten it after tuning the engine and it made it ok though the first flight and vacated during the second. It is the first time that has ever happened to me but it is the only thing I can think that caused it as I was taking the post mortum look at the engine and found the glow plug missing. The EF yak is still in the box. It will probably be a winter project. I have both that and a Ultra RC Katana to put together over the winter.
I am interested in what you think of the EastRC yak. Let us know.
Jeff
Old 06-11-2008 | 04:50 PM
  #87
Well went flying again today 6/11/08 i busted the 20/10 jfx on a landing, came in a little hot landed in the grass instead of the grass.. So i pulled the tail wheel off and that made the rudder flip up and wacked the prop just on the edge of the runway(paved) .......So it busted the prop, i put a apc 20/10w on it today at idle its 1400 rpms and full power its at 6100 rpms...... I've got a xoar 20/10 for it to try next i'll post what it is along with the weight next time i go flying!
Old 06-12-2008 | 03:52 PM
  #88
BarracudaHockey's Avatar
I test flew Kevin's Yak last weekend. I was fairly impressed. I own the EF 74"
I will say one thing, there's no way in heck that thing is 25 percent though.
Old 06-12-2008 | 10:01 PM
  #89
I dont understand?the measurements seem about the same as other planes listed as being 25%.73" wing and 66.5" length and approx 10lbs
Old 06-13-2008 | 01:12 AM
  #90
maineflyer, in between the time that I ordered my plane and when it got here, EastRC changed their website to reflect that the CF upgrades were no longer part of the deal. I called them and was told that they just found out that their last shipment didn't include the CF upgrades. To their credit they offered to send a return tag so I could send the plane back. I waited until the plane came so I could take a look at it. It looks fine so I called them back and they agreed to send me a 3000mah battery and I'll keep the plane. I got rid of my H9 EDGE / Saito 1.80 and ordered an OS 1.60FX for this plane. It should fly the skin off of it! The ARF weighs just under 6 LBS. How heavy was the Magic Hand ARF?
Sounds like you have your winter planned. I'll keep you posted on this project.
ifuller, the plane looks really lightly built at first look. a little scary in fact. we'll see if it holds together!! I haven't started work on it yet so I don't know much other than that it is a no frills arf.
Old 06-13-2008 | 05:32 AM
  #91
maineflyer's Avatar
My Feedback: (44)
Plowboy,
I beleive I weighed everthing at the beginning of the thread. My all up weight was listed a few posts back at near 11' 5 oz all up. I tried a CF rod from another plane (Maxair Velox) and it fixs perfect but is about 3" too long so I will not be able to use it unless the Velox bites it. It would save atleast 5 oz.
Jeff
Old 06-13-2008 | 12:49 PM
  #92
ORIGINAL: lfuller
Key words "listed as being" however, the full scale Yak has 8.16m wing span or 321 inches.
321 * .25 = 80.25 so it would have to be slightly over 2m to be true 1/4 scale, or IMAA legal as the 25 percent would seem to indicate.
Edit: The length is closer, it would have to be 68" (rounded down)
Old 06-16-2008 | 10:04 AM
  #93
I have mine put together and engine mounted. Ran it yesterday to check everything out and it ran great.
I have an SPE 40 in mine and think it will be good for this plane. It will maiden this coming weekend and I will post
a report.
Old 06-17-2008 | 08:44 PM
  #94
You'll like this plane.....It flys like a champ good luck can't wait to see how it flys
Old 06-19-2008 | 09:09 PM
  #95
Hi did you cross the rudder cables or did you run them straight on the MH yak?
Old 06-20-2008 | 06:12 AM
  #96
maineflyer's Avatar
My Feedback: (44)
I crossed mine, to help take the slack out of the lines when deflected.
Jeff
Old 06-20-2008 | 07:50 AM
  #97
Thanks jeff
Old 06-20-2008 | 01:10 PM
  #98
maineflyer's Avatar
My Feedback: (44)
Just got the invoice for my new cowl. Happy fathers day from the Mrs. I should be back in the air by next weekend. I am really looking forward to wringing this one out. Even have the matching shirt.
"Smoke On" from TBM Babeeee
Old 06-22-2008 | 03:45 PM
  #99
well i finally got a weight on the plank today it was 12 lbs 4 ozs not a bad weight glad i put a 45 cc in it!
Old 06-22-2008 | 05:24 PM
  #100
maineflyer's Avatar
My Feedback: (44)
I talked to the guys at TBM and they have more coming. they mentioned that the 2nd version will have a little longer nose for easier balance and CF Gear and wing tube. I should have my cowl by Wed. and be back in the air this next weekend.
