Help with Waterfalls >
Old 04-30-2003 | 03:59 PM
Default Help with Waterfalls
Hello all. I'm new to 3D flying and I have a question about Waterfalls.
I'm practicing on my Real Flight G2 using the Edge 540. It seems to snap out of the waterfall after about 180 degrees of rotation if I use full 40 degree elevator deflection. If I use less elevator it just does a tight outside loop. I have tried mixing in spoilerons and flaperons (which is correct?) and still no luck. Perhaps I need to move the CG back?
Anyways, I hope someone here can help me out as I'd like to get as much virtual "stick time" as I can before I get my UC3D built.
Thanks in advance,
Jon
Old 04-30-2003 | 07:19 PM
Are you flying the stock edge on realflight?
Old 04-30-2003 | 11:03 PM
I'm using the large Edge that comes with Add-Ons 4 . I moved the CG back a little, tweaked the thrust lines and increased the throws on all surfaces.
Jon
Old 05-01-2003 | 12:08 AM
My Feedback: (12)
Try blipping the throttle right as you give elevator input. Get it just about stopped and give a quick blast of full throttle at the same time you give full elevator.
Old 05-01-2003 | 12:54 AM
If you want i will send you any set up you would like, all 4 add ons.
Old 05-01-2003 | 01:37 AM
Chuck,
I normally apply full throttle and full down elevator from a stable hover...
Edgeomatic,
Thanks... I'll try what ever you want to send me!
Jon
