Just curious- what's ur final HSN setting in FA125?
I have my saito fa125 just run in. And the HSN is about 3 full turns off. I use 20% nitro fuel and 19% synth/castor oil mix. How about yours settings?
RE: Just curious- what's ur final HSN setting in FA125?
Number of turns depends on carb and brand. Even between saitos with different capicities are differences, thats why i ask particulary about this engine.
My Saito 125 is 1 1/2 turns out from closed. All my other Saitos, and Magnums are within 1/4 turn of that setting. I always run slightly rich.
Thanks for your answer. And now i'm a little confused with my 3 turns Must check if the tank keeps pressure.
So i checked fuel system and everything is ok. Tank keeps the pressure. Hmm, strange a little. But the fact is i didnt peak my engine yet, so maybe it will be even stronger with leaner settings
