seduction freestyle >
seduction freestyle
seduction freestyle
Old 05-11-2003 | 04:18 PM
mikey-3d's Avatar
Default seduction freestyle
i flew my seduction freestyle this weekend,and i have to say what a machine the way it flys is so stable yet wack the throws up and it goes ballistic,blenders,harriers,tourqerolls are all capable but normal pattern flying is acheived aswell,anyone out there flown one off these,what a toy
Old 05-11-2003 | 07:06 PM
Yeah,
They are't bad. What engine and prop combo are you running
Kris
Old 05-11-2003 | 08:19 PM
mikey-3d's Avatar
im running a ys 53 with 12,25by3,75 seems ok for power,prop hangs on half throttle tourqe roll 80 percent,fuel yamada 20 20.have you got one ? what set up is yours,im using 9202 futaba servos high tourqe, the elevator is so agressive,stops it dead,when wound up fully.
Old 05-12-2003 | 06:56 AM
I have the YS 63 on a 13 x 6 apc, the servos are hitecs 525mg ailerons and 605 for rudder and elevator. The 6" pitch alows me to fly like a patern ship with the 3d stuff mixed in. 13 x 4W for slow stuff.
Cheers
Kris
Old 05-13-2003 | 05:41 AM
3DMike's Avatar
What cg are you running at, my seduction flys like a pig...
Old 05-13-2003 | 08:41 AM
I am currently using 160mm from the TE. Which a far ammount of expo
Kris
Old 05-13-2003 | 06:18 PM
mikey-3d's Avatar
3d mike
im flying mine at 160mm from te ,flys ok,60%expo on elev,whats wrong with yours?i think this is an outstanding machine.
Old 05-13-2003 | 11:23 PM
I am building a Seduction Fun-Fly at the moment and plan to use an OS46FX for power. Is anyone out there flying this combination. I am especially interested to find out where the C.G. would be with this combo as I would hate to add any extra nose or tail weight. The quality of parts is superb indeed. I hope it will fly as well too. Intend to use Hitec mini micro 225s for the ailerons and Hitec micro 235 for throttle.
Old 05-14-2003 | 07:37 AM
The Hitec 225s are perfect and HS 85 for throttle. Im using them on the seduction FS.
Old 05-16-2003 | 11:15 AM
I've been building my seduction freestyle for 3 months on and off and should have it finish in a couple of weeks. Can either of you post some pictures of your finished plane (Inside and out) so i can get some ideas.
PS i can't work out the idea on the plastic piece around the undercarriage.
I'm going to be using an irvine 53 with an APC 12.25x3.75 prop.
Neil
Old 05-16-2003 | 07:36 PM
Here is a pic of my second seduction. The plastic piece is supposed to keep oil and dirt out from that area but I dont know why anyone would want to do that. I have left it out on both seductions.
Old 05-16-2003 | 07:37 PM
mikey-3d's Avatar
hi neil
that plastic piece sits at back off the undercarraige plate to stop ny oil etc from going inside off airframe.ill post pics when i get them,your set up should go really well,plenty off power with irvine 53.
mike
Old 05-16-2003 | 07:40 PM
mikey-3d's Avatar
fly777
wheres the pic it dosent seem to have got through?im flying mine tomorrow so ill take some flight shots.
Old 05-16-2003 | 09:16 PM
I could post some pictures of a bare airframe but i don't think thats of any interest.
Look forward to your photos.
Neil
Old 05-17-2003 | 09:06 PM
mikey-3d's Avatar
neil
what servos you going for?ill try and get pics tommorow,had two flights today then rainnnnnnnnn.
Old 05-18-2003 | 11:36 AM
Surrey3styla,
Got your pics. I thought the tank was meant to go up front, but will try the middle for CG balance. Last night i was shaping the wings and i started to sand the leading edge before putting the extra strip on. What a bummer, there's going to be a line of filler now.
I like the idea of strengthening the tail sections as these things alway twist when covering.
SERVOS
Not sure yet. I've got about 20 spare 148's, so unless i can decide i'll test it on them and replace later on. What are you using?
Neil
Old 05-18-2003 | 12:09 PM
mikey-3d's Avatar
im using futaba 9202s high tourqe,really work well with this plane especially tht big ele and rud.
Old 05-18-2003 | 02:33 PM
mikey-3d's Avatar
hi neil
got some static shots,weather no good today for flight shots but flew in gail winds anyway ,hope these are ok close up off control links from petetindals models.
Old 05-18-2003 | 02:45 PM
mikey-3d's Avatar
Default seductionfreestyle
didnt come out on that one
Old 05-18-2003 | 02:53 PM
mikey-3d's Avatar
heres one off tank position,just visible through canopy,
Old 05-18-2003 | 02:54 PM
mikey-3d's Avatar
and heres one in full colour scheme hope these are ok,
mike
Old 05-18-2003 | 04:21 PM
Surrey3styla,
What did you use to tint the blue canopy, or is it an Ono?
Glenn
Old 05-18-2003 | 06:21 PM
mikey-3d's Avatar
i used an ordinary tamiya spray paint for cars , sprayed on inside with very fine coats to give the transparent effect.
Old 05-18-2003 | 07:11 PM
I've tried dylon (fabric dye) before and got mixed results. You leave it in a bucket for 3 days and for me it wasn't bad but a friend of mine got a perfect transparent purple.
Neil
Old 05-18-2003 | 07:50 PM
mikey-3d's Avatar
sounds good neil but slightly more hassle than just a spray can,how do you apply it when its ready?what do you mix it with.
