os 91fx problem
My Feedback: (9)
RI
Hey guys my os 91 hasnt been run in about 3 years. upon looking over the engine alot of rust was inside, I used navy jelly i bought at lowes did the job. Its not sucking gas with very little compresion, could it be the piston rings ?
rust might have eaten some of the piston ring away as well as the liner and a bunch of other stuff. making a sufficient gap to loose compression (piston rings and sleeve), If I where you I would change piston liner (if it had rust) and the piston ring. Also check the carb, SPECIALLY the needle valve assembly which tend to get rusty and give everything a good cleanup. Change anything you see damaged. 3 years without use can be pretty tough on this engines. hope this helps!
You can find the replacement part here:
http://www3.towerhobbies.com/cgi-bin...I=OSMG0591&P=Z
garygee :
Remember to BREAK-IN your engine after you install the new rings! do it per manual exactly as if it were new. I know its kind of boring but it will give you way better performance once you do it. You can download the manual at osengines.com
