Lanier Cap kit diet. >
Old 05-25-2003 | 02:33 PM
h82crash's Avatar
Default Lanier Cap kit diet.
I'm working on this Cap kit and have already spent 3 hours lightening the fuse sides, greatly enlarging the existing holes and adding more. I can remove 1/3 the weight of the fwd bulkheads and motor box assy (1/4"-5 ply, no lighting holes.). I'm kind of using the Dave Patrick Edge as a guide to wood removal, there is so little to it. I'm wondering why this kit was designed so heavy. Is it because it was the way things were done 6 years ago? If I build it to plan, I could stand on this thing! Or,...am I way off base, thinking this is way over engineered?
Old 05-25-2003 | 10:53 PM
My Feedback: (12)
Default Plane testing
The Lanier planes are produced for the general flyer. Flight testing is quite brutal so the planes are somewhat over built. At least this is what I have been told. Most planes can be lightened including some of the best kits. Excellent flyer when you get it done however.
EXCAP232
Old 05-26-2003 | 01:29 AM
h82crash's Avatar
Here's what I've done so far. :tired:
Old 05-26-2003 | 08:25 AM
My Feedback: (12)
Default Low cal diet
Sweet but not fattening. Looks really nice.
EXCAP232
Old 07-11-2003 | 04:03 AM
h82crash's Avatar
I'm a little excited, all up weight minus covering, 11.5 lbs with an OS 160. Probably <12 lbs finished! That will mean about 13.5 with a DA 50! I take donations.
I'm gonna lighten the G62 and try to get it under 4 lbs-I could live with a 14 lb 81" Cap with 28 lbs of thrust.
BTW, thats a wing loading of 21.6 oz/sq ft for the OS and 24.8 with the DA.
Old 07-13-2003 | 01:05 AM
Default Lightened Lanier CAP
this looks good---why didn't I think of doing this when I built mine?? Be advised that that nearly all CAPS---including the Lanier---build tail heavy. Look to relieve any weight possible aft of the CG. If I were building another, I wouldn't sheet the bottom of the fuse aft of the wing, wouldn't use all the stringers for the turtledeck. I would use 1/32 ply for the turtledeck, probably would use 1/16 balsa to sheet the tail feathers. If you can build this plane with a gas engine at less than 14lbs, you'll be doing great. The lightest I've heard of with a 50cc engine was 15lbs.
