 Tower Uproar Mods. >
Tower Uproar Mods.
Tower Uproar Mods.
Old 11-14-2008 | 01:27 PM
Default Tower Uproar Mods.
Ok, I have a uproar 40 with a 46ax on it. I know that is more a sport plane then 3D but I've heard of people making the control surfaces bigger so it will hover. I can hover mine now for about 20 seconds at best then it wants to nose over. I think I'm still nose heavy though. My question is how much bigger should I make the surfaces?
Old 11-14-2008 | 02:03 PM
My Feedback: (12)
Default RE: Tower Uproar Mods.
I did a similar mod to a somethin extra. I added a counterbalance to the top of the rudder about 2" high and 1" to the elevators. Make sure you can get at least 45 degrees throw out of both surfaces. I didn't do anything with the ailerons except maxed out the throws. Start working the CG back slowly (so you can get used to it). And then practice, when you think you practiced enough then practice some more
Old 11-14-2008 | 03:56 PM
theradioflyer's Avatar
I added counter balances and wingtip gates or side force generators. The coupling is terrible for knife edge If I were to make the SFG again I would add equally top and bottom. This is my first plane that I ever did tail touches on the runway with. You may want to make it more tail heavy as well, I don't recall where I had mine.
Blessings,
Jay
ID:	1072105   Click image for larger version
Old 11-18-2008 | 02:35 PM
Daniel Z's Avatar
From: SantiagoReg Metropolitana, Providencia, CHILE
what can really improves is to put on a turtle deck, add a canopy and make the fuse much more taller, also SFG can be a good idea too, tall fuses and more lateral area makes the model roll better KE muuuch better and adds more rudder control, besides it will look much better!
