Recommend 3D Plane for a OS 56a
Hi,
i need a 3D Plane for my new os 56a, can someone recommend one for these 4 stroke engine?
I want to learn hovering with it !
My Saito 82a is still unemployed, too.
thank you in advance
maiky
maiky
I'd put that 56a in a Swany Fat Free Taco. I'd also look at the NitroPlanes Yak25. You could also get a Mojo 40 and build it light for foamy-style floating and power.
For the 86a...I'd look at the small line of Aeroworks planes. Maybe a Mojo 60 or an OMP profile plane. If you want more of an IMAC style plane, the Seagull 60-size planes are good, too.
I'm not sure what the stats are on either of those engines, but from what I understand that's where the range in which they need to be. Give us some more info and we'll probably be able to help more.
Hi
I have a friend that has that motor in a Mini Hype from Weston UK. flys very nice, no problem hovering. Would recomend that combo, a small profile would also be good.
That 82 is perfect for a Mojo 40 or any other 40 size planes,
The Mojo 40 is as good as it gets for learning to hover ,,
Omp has a good 40 size arf for learning to hover, http://ohiomodelplanes.com/47edgearf/index.htm
Swanyhouse Fat free taco for the 52 and defiantly a Swanyhouse mojo 40 for the saito 82. The mojo 60 prefers atleast a saito 91 or best a saito 100
http://www.swanyshouse.com/index.aspx
Haha...sorry. I thought that he had an OS FS-81a, not a Saito .81. That's why I recommended the Mojo 60. Definitely, a Saito 82 would be awesome in a Mojo 40!!
