Four Stroke or gas
Thanks guys for all your input.I'd use 15% fuel on this engine will try 30% if it's not better I think I'll try the 120 2cycle although I like the 4 cycles more but over here in South Africa the OS and Saito 4 cycles are much to expensive right now.
Thanks again.
Thanks again.
BC, CANADA
New is nice,you get full warranty.. or you could try something like this if on tight budget
http://www.rcuniverse.com/market/item.cfm?itemId=488194
My MVVS 26 IFS weighs 38 oz with ignition and the measured thrust with a Mezjlik 18X6 CF prop is 18 lbs. (with a pipe you can get well over 20lbs) It burns about half the fuel per min. that my Saito 180 does so I only run a 12 oz tank instead of the 24 needed on my 180 saving roughly 3/4 lb in fuel weight. I have mine in a Sig Mayhem at the moment and I am more than pleased with the performance. It hovers at less than 1/2 throttle and punch out is great. I confess that I haven't tried it in anything like the plane mentioned but I thought the numbers I had might help out some. Good luck with whatever you go with.
#31
OH
just breaking in my mld 28 and after 30oz of fuel getting a peak of 17lbs of thrust on a xoar 18/6 and the weight is exactly what is advertised on mldengines website. not bad for $265.
#32
MO
My Saito 125 pulls an 7-8 lb plane around great does use the fuel but man the power is awsume on this. My 180 pulls a Sundowner or did lol weight of around 13lbs. was not as fast as I wanted but faster than the pilot. The 125 has a 16x8 Master AirScrew and same on the 180. The 180 on this size plane to me could be bigger, but flew it good and done all i could do just speed was from 84-93 depending on wind and stuff when it came by radar.
