 fading gas engine >
fading gas engine
fading gas engine
Old 03-14-2009 | 11:31 PM
Default fading gas engine
My CRRCPRO GF50I motor seems to work for the first 5-10 minutes of flight and then suddenly slows to idle, After a minute or so the speed picks up again. All the other control surfaces carry on working normally. Ground testing has not solved the problem. I have also checked the fuel filters but no problem there either
Any ideas
Old 03-15-2009 | 12:16 AM
Default RE: fading gas engine
This should be in the Gas engine section.You'll find more answers there.
maybe you have a pump diaghram issue
Old 03-15-2009 | 12:17 AM
I see you already posted there,never mind
Old 03-15-2009 | 10:06 AM
tail strike's Avatar
My first thought is it is lean and getting hot that is why it slows down.
Larry S
