Battery setup question
MO
I just bought a Frenzy 100 I will be using 5 Futaba 3305 servos and 1 3004 (throttle) I ordered a Hydrimax 2000 Mah 6V .......My question is will this battery be enough for this setup...Is there anything I should know about this setup? My rec is 6v compatable
Yes, that will certainly be enough battery for your setup. You could expect at least 6 flights without charging. Maybe more.
