 tx programming >
tx programming
tx programming
Old 06-21-2009 | 10:30 PM
stumpknocker's Avatar
Default tx programming
whats up fellas, i just got a u can do 3d.46 with a futaba 7 cap radio. the u can do has 2 servos for the elevator (one for each side). does anybody know how to program the mix to have both of them work together? thanx.
Old 06-21-2009 | 10:57 PM
My Feedback: (13)
Default RE: tx programming
If you have the 72 mhz 7Cap.... you cant. What you will need to do is either use a Y servo reverser....or what I do is buy a futaba Servo synchronizer(MSA-10) or a JRmatchbox. Using the Synchronizer/matchbox allows you to electronically trim the servos/ set end points etc individually on the ground....and as a single unit in the air.
If you are using the NEW7C 2.4 ghz.... It allows you to use dual elevator under the Ailevator function - HOWEVER....there is a lag between the two channels. Its minor but noticable. Ive asked myself "So whats the point?"
I had the Older 7Cap....and now the new 7C and in both cases I have used the synchronizer.
PS - there was someone on here that was selling used JR matchboxes for a decent price in the for sale section.
Good Luck.
Old 06-22-2009 | 07:32 AM
thanks alot bud.
