Is this battery big enough?
CO
Hey everyone.
I am about to maiden my DP ultimate and just checking to see i have all the wrinkles ironed out. I am running 4 futaba 3004 servos in the ailerons, one hitec mini servo for the throttle, a very hi torque digital for the elevators, and a 1/4 scale servo for the rudder. Dave Patrick suggested using a 600 mah battery for this setup, does this seem a little bit small for this airplane? The help would be greatly appreciated. Thanks
Hi
I have used 1650...1700...& 1750 4.8 volt NMH for years
with no problems at all
Your best of with a fast charger with the higher capacity battery packs instead of a trickle charger
CO
I will stick to Nicads for now just for the sake of saving money (my ulty has used most of it). I think i will have to go bigger. my voltwatch goes to the yellow when i move all the control surfaces, so it cant handle the current. Phew, good thing i didnt fly this. Thanks for all your help. Do you think 1100mah is big enough its almost double, but i may go bigger just to be safe.
CO
What is the weight difference between a 1800 and a 600? Aobut 3 times as much? I want to keep the plane around 12 lbs. Its 12lbs 3 oz, with the current battery. Thanks.
