 micro motor & ESC >
micro motor & ESC
micro motor & ESC
Old 09-15-2009 | 11:43 PM
Default micro motor & ESC
Hi,I brought a 9.8 grm micro motor from Ebay and it says to you,se a 5-10A ESC,and a 2C lipo battery I have a Pentium 10A ESC and 2C Lipo 1000mAh 12C battery and get no response from the motor.I was wondering if I have the wires connected wrong but have heard that the motor should run forward or backwards when connected can anyone help,Thanks Creedah.
Old 09-16-2009 | 01:13 AM
Default RE: micro motor & ESC
is the ESC a Brushless Type ? if not it wont work with your brushless motor. if it is OK you need to do the transmitter program with the ESC and Motor with power on. also the lipo is way to big for a micro model , go for something no larger than 350mah / 2 cell. the 3 wires from motor to esc can go any way , if your prop is turning the wrong direction just swap over 2 wires.
Old 09-16-2009 | 01:46 AM
thanks for reply Freeair, I,ll Chase down a 350mah bat and give it a go. do you now of any micro 3D plans that would suit this motor and battery that give a CG location,Thanks.
Old 09-21-2009 | 02:43 AM
have a look at Hobby City . com they do have a micro Piaget that i want as i have its bigger brother Piaget. this might give you some info.
