 Knife Edge help >
Knife Edge help
Knife Edge help
Old 07-13-2010 | 03:31 AM
Ernie Misner's Avatar
Default RE: Knife Edge help
Dave, if you start adding rudder too soon doesn't it make the plane go off course though?
Ernie
Old 07-13-2010 | 09:13 AM
daveopam's Avatar
My Feedback: (9)
It can Ernie, but it would take a drastic rudder input to make it turn before it gets on knife edge. Start by moving your sticks slowly together(or apart) at the same rate. Once the plane is in knife edge you should know right away if you need more or less rudder deflection. At least with a little practice you will. Also start off doing them with all the speed you can stand. As you get better at doing them , then start to slow them down a little. Just keep some air under it as you find out how the plane will react. After all a snap input is what? Rudder, opposite aile and elev. Sound familiar?
david
Old 07-13-2010 | 03:23 PM
Which way do you roll best David? I am a left roller myself so I guess that is why it is more comfortable for me to KE to the left. We need to practice our unnatural way even more, right?
Ernie
Old 07-13-2010 | 06:33 PM
daveopam's Avatar
My Feedback: (9)
I agree Ernie. I am a left roller myself. I do a lot of right wing down doing 4 point rolls, but hardly ever start with the right wing down. It's a bad habit to get into. Kind of like doing all your approaches with a left turn. To cure myself of it I have been doing KE passes and then using the rudder at each end of the field to do a KE half loop and come back across on the other wing. I am still more comfortable with the left wing down , but I am getting more accustomed to the right down.
David
Old 07-18-2010 | 05:21 PM
Maybe they roll better to the right in Europe. I'm an old motorcycle flat tracker and just want to go to the left I guess. My chiropractor even starts on my left side.....
Ernie
Old 07-19-2010 | 09:39 AM
  #31
daveopam's Avatar
My Feedback: (9)
Could be Ernie. lol To throw a wrench in your theory, the guy I fly the most with is a right wing down knife edger. I tell him it's cause he is left handed. And maybe it is?
David
