pheniox funstar
WI
hello, i got a pheniox funstar from tower. was wondering if any of you that has this. added right and down thrust. manual shows 2 degrees down and right. does not appear to have any from factory. if so how much did you add or if even neccesary. any other comments appricated as well. thanks andrew wisc.
It is a nice airplane if you have the reflexes. I have the 60 size of the same called Topstar 60. They are built extremely light and tend to be pushed around by the wing. But on a good day and with the right setup you can make the nose chase the tail. I didnt have the Funstar myself but had a fellow flier who had it and got frustrated because he was more used to pattern airplanes. You may want to check the net for reviews
Ameyam
Ameyam
