RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Seduction Wildstyle / Freestyle (https://www.rcuniverse.com/forum/3d-flying-82/1078358-seduction-wildstyle-freestyle.html)
_shadow_ 08-22-2003 03:06 AM
Guys,
May I know what servos are y'all fitting into these planes? Whats the AUW? Will it come to 4lbs with standard BB servos or do I have to go mini digitals?
I just got my Wildstyle and planning for the servos..got a Saito 72 for it.
Thanks.
Regards
Marcus
jon595 08-22-2003 02:01 PM
I had regular servos in my Freestyle and they were fine. My Wildstlye has minis because I had them lying around. I have added about 1 1/4 ounces of weight to the tail because you cannot move any of the equipment around without cutting up the covering. Which by the way I have already done twice. If I knew in the beginning that I would have to do this when sorting out the CG I would have used standard size servos. BTW, the digital servos when used with the large tail surfaces set up for max travel tend to oscillate (like the pot is dirty). Standard servos do not do this.
Wildstyle 08-23-2003 09:40 AM
Hi Marcus
My wildstyle has hitec 225's all around with a hitec 81 on the throttle. engine is a Irvine 53 which has more power than it needs, all up weight is 4lb 1oz
FNG 08-25-2003 07:56 AM
Wild Style
Where did you guys get your Wild styles?
Any pictures?
Deanoo 08-25-2003 09:17 AM
Marcus
What is the scene like in KL?? I live in Dubai, UAE and I am thinking of moving to KL.
Jaco 08-25-2003 11:11 AM
Re: Wild Style
Any pictures?
http://www.modelrec.com/products/rcP...%20PILOT/LAZER
Lewd Skywalker 08-25-2003 12:01 PM
1 Attachment(s)
Hi! I'm from the Philippines.
Currently we have the first two Wild Styles here in Manila. A local hobby shop imported them directly from Japan.
It was a blast to build (perfect design/engineering) in 2 weeks time. Covered using Solarfilm (2 rolls transparent blue and 1 roll white).
Here's my Seduction Wild Style using an O.S .46FX for now (saving up for a YS63 :D), used JR NES537BBs for elevator and rudder, Futaba S-3001s for each aileron, and Hitec HS-81 for throttle.
_shadow_ 08-27-2003 12:23 AM
Deanoo
Email me at [email protected] and I'll brief you on KL.
Thanks to all who replied.
Regards
Marcus
jon595 08-27-2003 01:53 PM
I forgot to mention mine has a Saito 56F for power. It's a little lighter than a 72 so yours will need more tail wieght, or position the battery in the next bay further back when it comes time to balance. What are you planning on doing about getting more prop clearance? The 72 really needs to swing a 13" or bigger prop. The stock gear only gives you enough clearance for a 12" prop. :confused:
shadowspring 08-27-2003 02:29 PM
jon595
Is it true that the wildstyle has a much thinner airfoil than some of the other 3d's like the Flip? Looks to be a little thinner.
What do you think the planes greatest strength is?
jon595 08-27-2003 02:38 PM
It's about the same thickness. Not as thick as a Laser 3D or a profile plane. The wings for a WS are built exactly the same, one is then flipped over and glue to the other other one. What I am trying to say is it has no dihedral but the wing tapers ever so slightly the same amount on the top and bottom.
jon595 08-27-2003 11:30 PM
Wing thickness......
I just measured the wing at it's thickest point and it measures 2 1/8" at the tip, 2 1/2" at the root (fuse).
pauser98 09-11-2003 01:09 PM
RE: Seduction Wildstyle / Freestyle
I wonder if anyone has used a OS70 4-stroke on the Wildstyle? Mine uses a OS50SX, but I would prefer more torque.
Chris
Mike Jones 10-14-2003 02:40 AM
A good place to buy the wildstyle is www.singahobby.com
the only thing is you will have to email him for a price.
AdrianM 10-14-2003 12:36 PM
It would be a shame to put a standard OS 70 in a Wildstyle. Its just heavier and not as powerful as a Saito 72 or YS 63
The new Os 70 Ultimate might be goos if it weighs what they claim.
