Digital Servo on throttle
Hey all:
on my h9 Suhkoi, " Preinstalled Spktrum a6000" digital servo. it seems that Icant get it tuned in. I will set the idle, then Iget no responce untill Imove the throttle stick, then it applys the new setting it does this both ways. do Ineed a better servo? this is on a DA85. and Iam not that used to engines this large.... thanks Hope this makes sence....... If i adjust the idle down on the radio. before the engine idles down Ihave to move the throttle stick |
RE: Digital Servo on throttle
Simple way to check- connect another servo direct into the rx. you dont need to install it. see the response without starting the eengine. if its the same, its tx related.
lots of pepole have been useing standard Hitech HS 425 SERVOS on thorttel i don't really understand what your issue is ?
I was told and most of the fliers I know with giant scale use a good coreless analog servo for throttle. Their reasoning is that vibration can shorten some digital servos lifespan and with the digital servo constantly "looking" for center ;those little movements are not desired on the throttle.
ORIGINAL: flyinwalenda I was told and most of the fliers I know with giant scale use a good coreless analog servo for throttle. Their reasoning is that vibration can shorten some digital servos lifespan and with the digital servo constantly ''looking'' for center ;those little movements are not desired on the throttle. this is Bull**** ... stright up guy :eek::eek::eek: |
Indeed.
Vibration can shorten any servos lifespan, the fact that it's digital is irrelevent |
sorry it was a little confussing : But I found it....... the servo tray had come loose. when I would set idle at a good point. it would seem reset it self after throttleing up, and vice verca...... I know right !!!! hard to explane and hard to fiure out.</p> |
| All times are GMT -8. The time now is 04:40 PM. |
