Hype 3D Elevator Linkage
Anyone out there done anything other than the closed loop set up on the Hype 3D?
Does the closed loop work well enough and positively enough? Anyone using a pushrod idea? I'm not keen on cutting into the rear of the fuselage and mounting standard sized servos as I think the strength will be compromised. Neither do I think mini servos will stand the test of time on the elveators. Any thoughts/info? Thanks |
RE: Hype 3D Elevator Linkage
The pull pull works very well. Pain to set up. Took me a few hours to do the elevator and rudder.
Use the pull pull system,the whole model is set up for it and from what i heard it works well! I used two standards in the tail strength wasn't the problem the tail is as strong or stronger after I beefed it up however you'll find your c of g way back in 190 - 200 mm's and they recommend 180 max.
| All times are GMT -8. The time now is 03:25 AM. |
