prop u can do sf saito 100?
i buy a u can do SF, with a saito 100, please recomend me aprop, for 3D flying, i like make hover with my planes.
APC 15x4W
David |
I flew a 3d hobby shop sukhoi with a saito 100 swinging an apc 18x4w. a 15x4w isn't nearly enough prop for the engine, probably plenty for a u can do though.
Sorry, but no way a Saito 1.00 turns a 18x4W. Maybe you are mistaken about the engine or prop size? A 18x4W is better on a Saito 1.50 or 1.80.
David |
APC 15x6 (not wide)
2 Attachment(s)
Hi!
In my You-Can-Do .60 powered by a MVVS .91 two stroke the best prop so far is a 16x4W APC. So I guess a 1.00 four-stroke in the same plane can swing a 17x4W or there about. A 15x4 will be way way to small prop for that engine!http://www.rcuniverse.com/forum/atta...mentid=2129013http://www.rcuniverse.com/forum/atta...mentid=2129014 |
The MVVS 91 two stroke is much more powerful than the Saito 1.00 four stroke. A Saito 1.25 is still not enough to turn a 17x4W. Not trying to be a know it all, but many people read these post. I don't want to see them make a mistake.
David |
15x6 should yield good results. I have a saito 100 on my big stick 60 and have had really good luck with a wooden 15x6. I have not done any 3D flight with the big stick, but that prop would be worth a shot.
I have a UCD with a Saito 1.00 and I use an APC 16x6 prop. plenty of thrust.
