RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   please help me (https://www.rcuniverse.com/forum/3d-flying-82/1195954-please-help-me.html)
bridiXLT 10-11-2003 11:31 PM
please help me
i would like to know how to do a inverted flat spin
can anyone draw me a simple diagram of the stick position
and how do i got about entering a flat spin
any help would be great thanks
RCLIVIN 10-12-2003 12:13 AM
RE: please help me
The way I do it is to climb up about 300', cut the throttle, nose over & dive toward the ground, give right rudder, left aileron & down elevator all @ the same time, after the plane makes about three spins throw your aileron to the right & it will go into an inverted flat spin, once in the flat spin on some planes you can ease the ailerons back to neutral & throttle up a little to increase the speed of the spin. Not all planes will do a good inverted flat spin. I have a sig profile ultimate that does great flat spins & I also have a 1/3rd scale pitts that will only make about two spins & it just stops spinning & falls, still inverted. You can use the same move with up elevator for an upright flat spin.
Good luck
Gil
bridiXLT 10-12-2003 12:45 AM
great
Well thank you Gil
i am praticing on Flight model simulator with a great planes ucan do .60
and it works[>:]
i love it i am going to be getting my first aerobatic plane for christmas.
i have been wanting to take the next step up in flying to the wonderful world of aerobatics :)
thank you very much for your reply
Cheers
Bridi
bridiXLT 10-12-2003 12:50 AM
RE: great
oh by the way an chance you can explain to me on how to hover or is their a book out called hovering for dummies:D
stomper 10-12-2003 06:42 AM
RE: great
Hey Bridi
Check out Nathan site here for 3D manoeuvers > http://www.3drc.info/aerobatics/3d/index.htm
If you enjoy his site tell him so here >
http://www.3drc.info/suggestions.htm
Hope this helps.
