Hype 3D Servos
Guys,
I've had some JR DS8411s (11kg/cm torque) in my Hype since I built it but am going to raid it so those servos can go in my new Composite-ARF Extra. I was thinking of switching to DS8231 servos (6.5kg/cm) and wondered if these servos will still be man enough for full on 3D. Any thoughts/what are you guys running on this model?? Regards. |
RE: Hype 3D Servos
i dont own this model, but i own a flip. i run 148s on all surfaces and even with 5mm of slop each way i can do 3D. You WILL notive a difference wen you go over 5kg. Some people say you need 8kg to 3D a small plane but i dont believe this. If you run the servos on 6v (like i do) the torque will rise and the speed will definatly increase.
All i can say is that yuo wont have the performance like you did with the 8411s. BTW, is that your ferarie? |
RE: Hype 3D Servos
Ample,. with no disrespect to the model the 8411s were wasted in it ! I used Robbe FS 100s. Anything ovewr 4kg torque will be fine if you have them 1 per surface.
RE: Hype 3D Servos
Welsh3D,
I knew the 8411s were overkill but I was lucky enough to have 4 knocking around!! I'll probably get the 8321s as I'll be able to swap them into some of my jets/large scale models if I need to. edible_engine - yep, my Ferrari :D Extremely impractical for modelling though ;) |
RE: Hype 3D Servos
id like to have 4 8411s lying around, that would be nice......i kinda guess the ferrarie would be useless for moddling, a guy came up in a Noble the outer day to my patch, he had to hav ethe heli on the passenger seat and the flight box concisted of a tesco bag with a few bits in it..lol
RE: Hype 3D Servos
Fortunately I have another car and a trailer for all things practical!!
| All times are GMT -8. The time now is 03:42 AM. |
