RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   UCD 46 Servo Jittering problem. (https://www.rcuniverse.com/forum/3d-flying-82/1367077-ucd-46-servo-jittering-problem.html)
b1g_tex 12-21-2003 04:26 AM
Has anyone has a problem running the antenna wire down the fuse and out the tail? When I did that I get about 10 feet on a range check before it starts going crazy. I pulled the wire out and got it away from the servo's in the tail and it range checked good. But anytime I get the wire near the servo's goes back to being bad. What is the best way to route the wire and is it normal for servo's to interfere like that?
Jimmy
stomper 12-21-2003 08:18 AM
RE: UCD 46 Servo Jittering problem.
Try routing the antenna out the top rear turtle deck just behind the canopy and tying off on top of the rudder.
HTH
3DFanatic 12-22-2003 03:22 AM
Had a similar problem on the Laser3D. Is your actual RX within 3-4 inches of a servo? That's what caused my problem.
b1g_tex 12-22-2003 03:46 AM
well i routed the antenna line up like described and flew it a few times before the horizontal stab ripped off in mid-air and it crashed into the ocean. so a new plane will fix my problem. thanks for the help though.
Jimmy
stomper 12-22-2003 05:39 AM
ORIGINAL: b1g_tex
Jimmy
Oh Man!
Sorry to hear that Jimmy
