3W 150B2 Ignition
Can I use an ignition system off a DA100 on my 3W150? I lost a wire on the stock ignition.
DA ign on 3W
Yep, you sure can. IMHO, the DA ign produces a HOTTER spark than the 3W. Other than that, I feel that they(ign units)arethe same. Just different printing on the ign case top.
Enjoy!! Chris~ |
Re: 3W 150B2 Ignition
Originally posted by blowin dirt Can I use an ignition system off a DA100 on my 3W150? I lost a wire on the stock ignition. The DA ignition works on 6 volt's if there is a hotter spark realized it would only be as compared to the older 3W 4.8 units. Current 3W Ignitions also run 6 volts... |
3W 150B2 Ignition
It runs anyway. Dosen't seem to have the top end like the stock ignition. I will contact DA tomarrow and find out about timing. Thx for the reply.
| All times are GMT -8. The time now is 02:55 PM. |
