IMAC Rules?
I was wondering what the IMAC rules are. I saw that in the basic sequence of IMAC, you can actually use a non scale plane. Some people had UCD's and an ultra stick?? Can anyone explain this to me or gimme a link. All help us appreciated
Thanks |
RE: IMAC Rules?
I'm not 100%.But iI believe the basic allows any air craft.After that It must be within 10% of scale.Deductions for no pilot or dash!
RE: IMAC Rules?
www.mini-iac.com For the basic sequence, you can pretty much use anything. I've heard of some cd's not allowing f3a type pattern planes, because of the obvious advantage they have over a scale plane, but that's all up to the cd. I've never seen anyone turned down before though, so you shouldn't have a problem.
RE: IMAC Rules?
10% rule wont be in effect until 2005. and then, i doubt it will be enforced very much. plus, 10% has a pretty generous leeway. scale determined by wingspan of full size.
go to this page on the imac website for ama rules http://www.mini-iac.com/pages/rules/imac_rules.asp |
RE: IMAC Rules?
GO to to the JR challenge this weekend.
You will see a lot of good flying and be able to talk with pilots who can answer any additional question. http://www.scaleaerobatics.com/ ORIGINAL: halfandhalf825 I was wondering what the IMAC rules are. I saw that in the basic sequence of IMAC, you can actually use a non scale plane. Some people had UCD's and an ultra stick?? Can anyone explain this to me or gimme a link. All help us appreciated Thanks |
| All times are GMT -8. The time now is 07:28 PM. |
