Acromaster 3D
1 Attachment(s)
Hi Guys,
I have just ordered from Austria (www.lindinger.at) a trainer for 3D, called Acromaster 3D . I have a O.S. .91 engine. for this plane. The details are given below. Could you suggest a propeller for this set up. ( I have tried O.S.'s web site, they advised me to contact to the plane's manufacturer. ) Technische Daten: Wingspan: 1580 mm; Length: 1630 mm; Weight: 3200 g; Engine 2T : 10 cm³;4T : 15 cm³ Thank you for your inputs in advance. Regards. Zafer |
RE: Acromaster 3D
I would suggest a 12x6 APc or a 13x4W APC. Personally I would choose the 13x4W APC.
RE: Acromaster 3D
ORIGINAL: Funtana_Cody I would suggest a 12x6 APc or a 13x4W APC. Personally I would choose the 13x4W APC. |
RE: Acromaster 3D
What do you think about 14x6 APC.? Thou it is a bit costly.
Zafer |
RE: Acromaster 3D
Too late to worry about cost now, you have ordered the plane :D
14x6 is ok. |
RE: Acromaster 3D
Hi,
Finally I got my Hype Acromaster 3D finished . Hopefully I will go to the field tomorrow and after break in I will try to fly the plane. Set up is O.S. 91 fx ( inverted) hitec 635 hb servos in rudder and elevator, 475 in ailerons and throttle. Hitec receiver and 6 V batt. I am still waiting my perry pump and on board glow to arrive. ( I think I will add them later). I am not waiting to much from this plane since this is my first all-round trainer. In a year I have flown and crashed trainers and spads. But still I am a little bit nervous. Wish me a good luck. Regards. Zafer |
RE: Acromaster 3D
1 Attachment(s)
Hi again, I forgot to put the photo.
Zafer |
| All times are GMT -8. The time now is 07:14 AM. |
