RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   U-CAN-do 46 on Floats (https://www.rcuniverse.com/forum/3d-flying-82/1810741-u-can-do-46-floats.html)
Plane 8 it 05-13-2004 12:19 AM
1 Attachment(s)
thought I would post a friends pix for him.....
if intrested I have more pix
Plane 8 it 05-13-2004 12:29 AM
RE: U-CAN-do 46 on Floats
1 Attachment(s)
here's a few more
autoguns 05-13-2004 01:03 AM
You flying off mirror lake?....that looks like Don's plane....JW
Webjammin 05-13-2004 01:59 AM
That is sweeeeeeeet.
I am impressed ;) may have to give that a try.
fiveoboy01 05-13-2004 02:11 AM
That is really cool!!!
Did your friend buy the floats, or did he scratch build them?
Plane 8 it 05-13-2004 02:38 AM
bought them....I will get a run down what all he has done to modify the plane...ect.
Plane 8 it 05-13-2004 03:07 AM
1 Attachment(s)
a few more pix
seanychen 05-13-2004 07:51 PM
I am planning on doing the same w/ my UCD 3D 60 size. You just motivated me that much more!!! The benefit of flying 3D on water is that crashes are more forgiving...:D:D
lost soul 05-14-2004 02:35 AM
the u can do here,has store bought glass floats,about sixty bucks,i believe.
the floats are mounted one the u can do landing gear,i had an extra landing gear from another plane from the past.lol..
i mounted the back gear just behind the wing,i did go in the fuse and beef it up a little.and i used a couple of wood screws to hold the landing gear inplace.
when i put the wing on,i unscrew the the back gear,slide the wing in,and screw the gear back in place,works well.
TooLy 05-14-2004 08:33 PM
Cool, but how he can turn in the water? I don't see any steering control in the rear .
Plane 8 it 05-14-2004 10:56 PM
there is plenty of prop wash across the flying contriol surfaces that a water rudder is not necessary although it would be nice to have when the wind picks up a bit...
it goes from floats to the field in about 10 minutes.(changing from floats to wheels)
Plane 8 it 05-19-2004 03:33 AM
well have u got your 60 on floats yet.....I am thinking, I will do it with mine...I have the O.S 91FX swinging a 15x4 and if I spend the time, I think it will 3D pretty good.....not like wheels of course. but I have read of a funtana on floats that is doing well...
buuuuuut we'll see.....I pave runways highways and roads so I might not have the time to get it on floats this summmer.....but if I do it will be posted here.....or there(the forum for the 60)
broken prop, broken prop rah ,rah, rah,....... does your club have a secret handshake too?
