RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Laser 3D mods / pics (https://www.rcuniverse.com/forum/3d-flying-82/1919687-laser-3d-mods-pics.html)
3D FREESTYLE 06-20-2004 05:52 PM
Hey i recently started building my laser and have already completted the wing. i am planning to put the new saito .82 and all standards except for the rudder im using one with 77 ounces of torque. looking over previous forums i have noticed a need for modifications however i have not been able to find exactly what i need to do. so i would like to possibly have a list of the mods and if you want some pics of what was done. this is my first 3d plane and i want to do it right. thanx
p.s. feel free to show pics of ur lasers :D
STLPilot 06-20-2004 08:36 PM
RE: Laser 3D mods / pics
1 Attachment(s)
Heres my Godfrey Laser 33% with BME 102.
3D FREESTYLE 06-20-2004 10:03 PM
thanks but i ment the laser models laser 3d.;)
epc 06-20-2004 11:47 PM
OK.
The basic. mods.
-reinforce the firewall and use an aftermarket engine mount ( I'm using a GP 40-60 on mine with a YS 63 )
First I used the wood stock mount and it was not strong enough to handle my Ys so with the saito it'll be the same story.
What i did was to glue the stock firewall and then a 1/8 doubler , made a hatch under the tank and installed the blind nuts for the engine mount.
Some guys reinforced their tails, I didn't do it with mine what I did was to build the tail with the hardest balsa stick that I could.
The rudder servo is mounted in the tail.
You'll enjoy this plane no problems so far with mine , great performer.
Hope this helps.
If you need more info or pics. let me know.
epc.
a340 06-21-2004 03:05 AM
1 Attachment(s)
I used a Du-bro anti-vib mount with a YS63S, sheeted all flying surfaces with the thinest balsa I could find and then cut out lightning holes. Didn't reinforce the tail. She was a great flier until I had a mid-air and lost!! Bought another kit already.
Leigh.
3D FREESTYLE 06-21-2004 12:15 PM
epc, thanks for the info, if you could send some pics thatd be great also how do you mount the servo in the tail. i notice some guys built it without wing tips whats that about. i dont meen to sound dumb because this is not my first kit but how is the tail whell conected to the rudder (if it is) because the instructions arent too clear on that.
-thanks 3D--
3D FREESTYLE 06-21-2004 12:16 PM
a 340 your laser looks great thanks for the pics
epc 06-21-2004 02:33 PM
1 Attachment(s)
a few pics.
I built mine without the wingtips but just because I like more the way it looks without the wingtips.
epc.
epc 06-21-2004 02:53 PM
1 Attachment(s)
2 more pics.
epc
3D FREESTYLE 06-21-2004 09:00 PM
epc , thanks for the pics just one question could you post one of the whole plane because i think that you have done the same color scheme i had previously decide to do and am curious to see how it looks
epc 06-21-2004 10:56 PM
1 Attachment(s)
Here you go.
epc.
MicroMac 06-22-2004 03:48 AM
1 Attachment(s)
Some Laser 3D pics: http://home.online.no/~helnaess/Laser3D/
- Original engine mount (Irvine 53)
- Tail&Elevators reinforced using some balsa and carbon
- No wingtips
- Pull/pull: Du-bro cevlar
- Some minor reinforcements here&there
Servos: Ail 225MG El 225bb t HS81 ru 475HB
Weight 2200g
30+ flights so far no problems.
LS171Malibu 06-22-2004 03:55 AM
1 Attachment(s)
I would suggest a longer landing gear. Mine has only a half inch of clearance for a 12.25" prop.
MicroMac 06-22-2004 04:49 AM
Use 13x4 APC, clearence about 3/4 inch.
Agree Laser 3D could use a longer landing gear.
3D FREESTYLE 06-22-2004 12:21 PM
thanks for your pics those all look great. i still cant decide if i hack the wing tips or not so any more input on that would help. i am most likely going to put a after market mount for the engine and mount the rudder servo in the tail. question for a340 , is that a stock canopy and if not what is it and where can i get one it looks great.
i think the color scheme im doin is a little closer to micro macs, once again thanks for the pics and info
MyWay 06-22-2004 12:40 PM
Wing tips? Wing tips? You don't need no stinkin wing tips.
mikey-3d 06-22-2004 02:35 PM
hey malibu nice scheme,ive sold my laser now but gonna build another one:Di miss it and seeing this thread has decided it for me.this time though i will brace tailplane as i thought with my previous one it moveed to much for my liking,especially in prophang the elevators used to vibrate wildely[X(]i to modified the mount with a plastic job,cool plane though[8D]
MicroMac 06-23-2004 04:29 AM
Wing tips or not? I decide not to use them based on what CHM says. He have tried both. A lot of excellent information in prev Laser 3D topics... do a search.
Rudder servo in tail or not, for me that was just a CG issue. If your Laser is nose heavy put the servo in the tail.
Only thing so far i don“t like is that big Irvine muffler... its heavy, and the t servo is located on the same side. I had to put 20+ g led in right wingtip.
Macs muffler is on the buying list, I will save 50g muffler wight and some led.
Relevant topics: http://www.rcuniverse.com/forum/sear...mitbutton=+OK+
Hercmate 06-23-2004 06:29 AM
epc,
not sure its wise to use a plastic spinner with a YS63? At the very least it should have an ali backplate!
Andy
stratosman 06-23-2004 09:51 AM
1 Attachment(s)
Here are some pictures of mine.
Upgrade your landing gear if you fly on grass, the gear that comes with it is to short
epc 06-23-2004 10:03 AM
Andy:
If you look closely to my pics you see that the spinner has an aluminium backplate.
epc.
JPMacG 06-23-2004 11:38 AM
Ditto the comment about the stock mount. Mine started to break loose after the third flight. I reinforced it with some hardwood square stock and screws. Its holding for now. My engine is a Saito 72.
3D FREESTYLE 06-23-2004 01:02 PM
1 Attachment(s)
would it work to put some hardwood square stock on both sdes of the mount and bolt it to mount and fire wall as i have poorly illustrated the darker is the hardwood. stratosman your is awesome i liek the patriotic color scheme. once again thanx. -3D-
a340 06-23-2004 01:22 PM
Hercmate was right about the spinner, the YS ripped it apart when I throttled up just after starting it, luckily I was stood behind the model at the time. Ended up using a Dubro domed nut instead.
3D FREESTYLE, I used the stock canopy and sprayed the inside with a Tamiya smoke colour spray that the car guys use.
Some nice looking lasers out there. On my next one I don't think I will put on the wing tips, Pain in the a**e to cover!
Leigh.
Hercmate 06-23-2004 04:41 PM
epc, sorry didn't see that, just didn't want you to get hurt! :D
I always use Tru-turns on YS's but thats cos I'm a flashy git :)
