RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   How to do knife edge spin? (https://www.rcuniverse.com/forum/3d-flying-82/1977966-how-do-knife-edge-spin.html)
3dandpatternflyer 07-10-2004 02:31 PM
can anyone explain to me how to do a knife edge spin??
Andrew T.
Rhilluk 07-10-2004 04:52 PM
RE: How to do knife edge spin?
many ways to do one. I normally do it by pulling up into a vertical climb stall turn 270^ to the left. Then hold that position with rudder and push full down elevator with what ever power is required. You'll need to add aileron, rudder etc. to keep it in it. But that works for me and my flip.
Nogyro 07-10-2004 08:25 PM
Good description, now how about getting out of it.:D Anything special?
Spaceclam 07-11-2004 08:26 PM
lower your throttle and give it opposite elevator. in some cases you can simply let go of the elevator
Nogyro 07-11-2004 08:53 PM
Sounds simple enough, I'll have to give it a try next time. :)
redbirdy 07-13-2004 12:12 AM
The best way to exit is to go into an inverted flat spin.
Spaceclam 07-13-2004 12:20 AM
if you plane is tailheavy you will never make it out of the spin. a flat spin can be self sustaining while a knife edge spin can not.
Spaceclam 07-13-2004 12:36 AM
http://www.infos-du-net.com/images/smilies/lool2.gifhttp://www.infos-du-net.com/images/smilies/ptdr.gif
i have a use for these smileys here on rcu. it will not let me save them on my computer. could somebody save them and email to me? the lol-bonk on the head thing is one unit. they are GIFs
redbirdy 07-13-2004 03:30 AM
If you can't pull out of a flat spin because you are too tail heavy, you shouldn't be flying in the first place.
Spaceclam 07-13-2004 09:15 AM
some planes do not fly that poorly when they are that tailheavy. one of the guys at my club had a plane like that. guess what happened...
willembad 07-13-2004 04:47 PM
Hey Andrew,
Do an inverted (full down elevator) spin with "wrong" rudder (same direction as aileron) and let me know what happens.
When you coming to the field again?
Later,
Willem
Spaceclam 07-13-2004 05:08 PM
williembad, are you talking to me or another andrew? if you are talking to me, do i know you? when i give it wrong rudder it turns into an inside snap roll in my yak. what about it?
3dandpatternflyer 07-13-2004 07:37 PM
Hey Andrew,
Later,
Willem
Actually, i can do the knife edge spin now, but Thanks.
I don't know when i'm coming to the field again, jus got back from Sebring(july 13). I'm in Orlando right now. I heard Mike McConville was there on July 4.
I gotta look for a job so i can get that 30%er. Lemme know when u finish your yak.
SPACECLAM, willembad is talking to me. Guess we have the same name.
TTYL,
Andrew T.
Spaceclam 07-13-2004 07:53 PM
lol. sorry
