Prop for U CAN DO 3D with 0.75 Engine
I have U CAN DO 3D with Tower Hobbies 0.75 on it.
It does not pull from vertical. what would be the best prop size for 3D Thank you. |
RE: Prop for U CAN DO 3D with 0.75 Engine
which size UCD do u have thye .46 or the .60. I have the .60 size and i use the 15x4 wide prop. It pulls out of everything that you do on it
I have a Goldburg extreme 330 profile with a .75 Tower on with a 12 1/4 X 3 3/4, instant throttle response, pulls verticle out of sight and hovers at 3/8 throttle and weighs 5 1/4 lbs. I use 10% nitro omega fuel and it turns 14800 RPM's on the ground.
Thanks Gatorboy, I will try 15x4 and 10% nitro.
Andrzej |
Witam Andrzej czy ty nie jestes z Polski?
| All times are GMT -8. The time now is 08:21 PM. |
