RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   elevator servos (https://www.rcuniverse.com/forum/3d-flying-82/2457421-elevator-servos.html)
stiopa 12-22-2004 07:23 AM
elevator servos
I`m planning to bulid 3D plane such as 3W xtra-fun of Funtana 140. I want to put 2xHS-225MG on elevators. Would that be enough?
I`m going to use 6V.
Angus Balfour 12-22-2004 09:23 AM
RE: elevator servos
I work that out to be just under 5kg/cm. Prob be ok with 2 but you may want something a bit stronger.
If you want a mini why not try two JR 9411. Metal geared and you get virtually 6kg/cm torque on 4.8V :) These are really good servos.
Angus
George E. 12-22-2004 02:13 PM
RE: elevator servos
The 225's are LOUSY servos. I have two of the 225MG's and they center lousy and hold lousy. You would be much better off with a standard futaba 3004, forget the specs the 3004's have more holding power.
Personally, for a strong, light, cheap servo I'd use a Hitec 5475 digital for $35 or the plain old hitec 475 for only $18.
Trust me, the 225's are junk [:'(]
