flip 3D with OS 70 ultimate....help setup
I just bought a flip 3D and set it up with an OS 50SX initially with an APC 11x6, but no good. Not to mention zero nitro fuel. I love the feel of the aircraft. It floats more than it flies. The wing loading is amazing. close loops, prop hang, flips, tumbles n what not!! all this with an engine thats simply not designed for this kind of an aircraft. It revs too fast n the transition due to fuel is poor.
so, i ended up buying an OS 70 ultimate for this aircraft. Now the problem is that i tried to start it up on the same 80/20 fuel n on the same needle setting ( the book says to start at full throttle n 2 rotations of the needle valve) the engine rpm varies from 1500--6000. this too for about 15 secs, then the engine shuts down automatically. what could be the cause? how do i fix it? keep in ming that this is a pumped engine. |
RE: flip 3D with OS 70 ultimate....help setup
we had one that did that and leaked fuel out of the back of the motorwe called OS about that and had to send it back. i believe it also said something in the manual about it ,cant remember
check for fuel line leaks and make sure your tank is not leaking. being a pressurized system like YS it can split your tank and not pressuring up . also make sure your fuel inlet and overflow are closed and not leaking. |
changed the fuel to 5% n the engine started singing...no problem anymore. thanks for the help.
anyone willing to discuss their setup on this aircraft? |
| All times are GMT -8. The time now is 03:05 PM. |
