mixing
hello all. just one question: I have 91rfs on giles202 and when I apply full throtile, plane rolls little and takes nose bit right. I know the last can be adjusted by engine mount, but do I need to mix throtile>rudder and throtile>ailerons? and if yes, how much %
thanks in advance |
RE: mixing
if you are just level flying and this happens just correct motor thrust line by whers or simmilar..
when pulling a vertical line does it also pull right.... also inverted how does it pull.. What kind of plane what motor? |
| All times are GMT -8. The time now is 08:23 PM. |
