RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   somthin extra 3d? (https://www.rcuniverse.com/forum/3d-flying-82/288403-somthin-extra-3d.html)
da king 09-25-2002 10:14 PM
somthin extra 3d?
I have a somthin exra and guess what it wont 3d.any help?
flytime56 09-26-2002 09:49 PM
somthin extra 3d?
I have the same airplane, first, you need to make it tail heavy, move your cg at least 1/2 inch more back. also, you need to give full travel on your rudder and elevator. ailerons also need much more travel as well.
remember, this is a heavier plane for a 3d aircraft. the rudder is not large enough for proper flat spins, making a addition to the top of the rudder will really help. if you want real 3d, you need more surface on your rudder and elevator. also, take out as much weight as possible, light wheels, light batteries, every ounce makes a difference.
all of this will help, but will not be as good as a lighter plane, and you need a good power plant with a large diamater prop with around an average pitch.
GB
da king 09-26-2002 10:15 PM
somthin extra 3d
thank for the info.I have 2.25 inch travle on elev.rudder is a cap 232 which is 1 inch longer on top and 3 inchs longer on bottom.travel is maxed.os 46fx 11x4 prop and macs muffer.hovers at 1/2 throttle.just tried the rudder today.i can go from torkroll to knifeadge no problem.hovers beter.still need to move cg back more.eleavators are ok.walls are cool.will not waterfall yet.havent weighed it yet, but have others to compare with and mine seems to be liter.its an arf.
CAP-tivating 09-27-2002 10:29 PM
somthin extra 3d?
Hello, I got a SE as well. Mine will waterfall quite nicely.
Here is my setup
-SE kit
-.46 FX on Cool Power 15%
-12x4 APC
-Standard radio gear with rudder and elevator servos mounted in the tail.
-C.G. is 1 3/4" back
-Stock tail surfaces
-Weight is 5lbs
I now runs with 2 1/2" of elevator travel.
da king 09-27-2002 11:37 PM
somthinextra
well lets see.
46fx with 11x4 i was thinking about a 12x4
cool power 15%
macs muffler
im only at 4inchs
i do have a bigger rudder about 1.5 inchs
elev travle is 2.5
how and where did you put the servos in the tail?
thanks for the help for some reason people arnt real helpful on this plane.
chasot 09-29-2002 11:31 AM
somthin extra 3d?
i have one at 4 1/4" CG with saito 72 batt. is half way to tail
servos are in stock locations but are all mini 225bb batt is 700mah etra jr pack i too added to the tail 1/2" to elevators 1 1/4" to rudder,have throws to phisical limits.
da king 09-29-2002 12:58 PM
somthin extra 3d?
chasot will yours waterfall or elevator?i played with props yesterday. im flying a 12x4 now. it didnt really give me any more power but it did smooth out the hover. its a lot easyer now. but the waterfalls are worse.it came in at 5lbs which isnt that bad.the kinfedge got a little better but nothin to right home about. i did move th cg back a ton but i would have to check to see where its at.
CAP-tivating 09-29-2002 01:02 PM
somthin extra 3d?
da King,
Basically for the servo installation all I did is square off the holes on the back of the fuselage right a the stabs leading edge, glue a piece of ply wood in flush with the fuse sides (with epoxy) and then a straight linkage setup. The linkages are only about 5 inches Long. The rudder servos was mounted on the bottom of the fuse with a mini pull pull setup. I hinged the rudder with those square plastic hinges with the metal pin in them. I remove each individual pin a replace them with one long piece of music wire. I did this so I can interchange different rudders.
I will try to get some pics if you want but it might take a day or so.
Cap,
da king 09-29-2002 10:40 PM
somthin extra 3d?
cap
yes i would love to see pixs.i checked the cg today and im at 4 1/4.its starting to hover real nice but the wind has a real big effect on it.also are you using spoilers for elevators?
Gbee 09-29-2002 11:24 PM
Somethin' Extra 3D
I just won a Somethin' Extra kit at my club's fun-fly. I don't have a small engine except for an OS .91 Surpass II. Would this be too much engine for this plane (too heavy)? I would mount the elevator & servos in the tail, maybe add an extra wing bay to each wing and increase the control surface dimensions? Or should I sell it and get somethin' better for 3D with the OS .91 4 stroke?
CAP-tivating 09-30-2002 01:02 AM
somthin extra 3d?
da King,
I will post pictures of my SE but like I said in my last post it will take a day or so till I get them.
I to find hovering difficult in windy conditions. Its taken me about two years to be able to hover adequately. Just keep on moving that C.G. back slowly. You may find the SE to not fly as well at high speeds with an aft C.G. I have not tried spoilerons (is that what its called?) in harriers. I was going to try them out but mother nature is not cooperating.
Gbee, Well you could try your .91 in the SE. You should at least have good vertical ;) . I think I recall some one with a .91 FX in a SE. A nice .50 class engine would be a better choice.
Cap,
da king 09-30-2002 01:55 AM
somthin extra 3d?
Cap
I did maneage to get it to "camp out" in a hover today. I got about 10ft down and chickend out. I did notice that the farther I got the cg the better it hoved but Im still dialing in. This is only the 2nd weekend Ive had it.
thx for the help...
EXCAP232 09-30-2002 07:32 AM
Re: Somethin' Extra 3D
Gbee,
The OS will be way too much engine and also too heavy for the Somethin Extra. Get a UCD-3D from Great planes or up to a YS-63 for the Sig.
EXCAP232
CAP-tivating 10-01-2002 08:59 PM
somthin extra 3d?
1 Attachment(s)
Here's a pic.
CAP-tivating 10-01-2002 09:01 PM
somthin extra 3d?
1 Attachment(s)
And one of the tail!
da king 10-01-2002 09:47 PM
somthin extra 3d?
I like the pix of the servos. I might have to build a kit and do all the mods ive been thinking about. soooo how do you tell which way its going in the air?lol.
CAP-tivating 10-02-2002 01:07 AM
somthin extra 3d?
I'm usually flying right in front of my self so orientation is not a problem. It actually is very easy to see in the air. I covered it sold white so when I screw up in a low hover all I have to do is glue her back together and slap some white monokote on her. That good ol O.S. engine has saved me a couple of times, no incidents yet!
Cap
da king 10-02-2002 01:27 AM
somthin extra 3d?
lol. sounds like you fly like I do.the wind has been pretty bad the last two days so i cant go burn fuel. I will defintly be moving cg back a ton.
Robert300XS 10-02-2002 06:25 PM
somthin extra 3d?
1 Attachment(s)
*Cough* :D
This was my "Prototype" tail, my new SE has a cleaner setup. As you can see with that one, I had to make an emergency move of the 45 cutout so it looks bad.
Robert300XS 10-02-2002 06:27 PM
somthin extra 3d?
1 Attachment(s)
Side...
My new one also has nearly 90 degrees of down throw... does a spectacualr waterfall! I also saved a little weight on it.
Do any of you guys notice the tail wobble back and forth in flight when you go slow or fast?
da king 10-02-2002 07:36 PM
somthin extra 3d?
I dont notice any wobble in flight. If you do I think its too much rudder or elevator.By the looks of that tail that might be you problem.That tail is HUGE!!!!!!!!Last night I build a cg jig and my cg wasnt as far back as I thought.It was at 3 9/16.Now its 4.5. Ya baby the next flight is gonna be wild.hopefully it will start to waterfall and elevator.
Robert300XS 10-02-2002 09:08 PM
somthin extra 3d?
nah, this one didn't wobble, i was just wondering :p
da king 10-03-2002 12:19 AM
somthin extra 3d?
just tryed my aft cg.its horrible in the turn without power but the hover is definitly beter.way more control.elevators are getting better but still wobbly.still wont even think about doing a water fall.flat spin is pretty much the same but i have a few things to do yet. I may have to buy a better 3d machine here soon.
