RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Hangar 9 - Extra 260 - Electric Conversion (https://www.rcuniverse.com/forum/3d-flying-82/3046838-hangar-9-extra-260-electric-conversion.html)
red_z06 06-06-2005 08:38 AM
1 Attachment(s)
Electric Fanatics:
I am in the process of building and converting Hangar 9 Extra 260.
This forum was started to share ideas among fellow electric fanatics and to inform would be future electics fans.
I will skip ARF assembly to Glow Threads and focus on Electric Hardware install and flying (later)
I chose this airfame for two reasons.
1. long hatch for easy battery access.
2. successfully flying funtana 90 conversion.
3. lured into it by advertized weight of 11.5lb on low side
Hmmm that is 3 reasons.
The airframe is built with servos installed ( pull-pull ) with no mount yet. It is about 8lb.
It has 4 Hitec 5625MG and 1 5955TG servos
I am going with Axi 5330/18 with 9s setup and Jeti advance 90amp controller.
Because I'll be flying 9S pack instead of 10s for ease of parallel charging and pack use in multiple planes ( H9 Super Cub, Funtana 90, Pacific Aero Edge 540/90. GP Little Toni, GP UCanDo 30 60 ).
My expected power input is about 3500W for a flying weight of 14lb for 9S4p and 13lb for 9s3p. Initial motor test will be performed with 22x12E prop and adjust according to Whatt meter to have a full throttle amps of 95-100.
I will be going with Espritmodel's Aluminum mount for the motor attachment.
Here is the pic of little brother to Axi 5330/18 which is 5320/28 in Funtana 90 with 9s2p 15c 2000mah cells with 19x8e prop.
red_z06 06-07-2005 11:42 PM
RE: Hangar 9 - Extra 260 - Electric Conversion
1 Attachment(s)
Aluminum motor mount from espritmodel came!
4" extensions were ordered and they are shortened to 3.8"
red_z06 06-07-2005 11:49 PM
1 Attachment(s)
Pictures of home charging (make sure your eyes are on the display at all times if you plan to charge inside) and field box.
2 packs shown will be powering the Extra 260. These packs are currently being used on my Funtana 90. Having 3 packs allows me to fly every 20min at the field.
BoneDoc 06-08-2005 06:57 AM
lol, you should move it to the 3D electric forum then :D.
But on the serious note, a couple things you need to do
1. Reinforce the landing gear with Kevlar (see the other thread) or get the Graphtech instead
2. tighten all your screws on the linkages.
3. make sure you use 1.25- 1.5" servo arms for the elevator for max throw
I think electrics are cool. I just don't have the money for it at this point.:)
red_z06 06-08-2005 07:17 AM
BoneDoc:
Thanks for the info.
I was happy that I did not have to by another Graphtech for this model due to prop clearance but I guess I still have to...
I was praising good hardware ( cf tail gear, cf main gear ) but I'll have to retract.
All machined screws are locktited. Hmmm I forgot the wheel collars.... Gotta do that too.
Yes the price goes up exponentially as size increases.
But at 90 size ( funtana 90), it is quite doable.
In my funtana,
Motor + ESC: $388
Kokam 9S2P 15c 2000mah cells: $420
Total $808 for 4-600 10min flights
If you do YS
YS110: $360
Fuel (10 flights/gal @$20/gal): $800
Total $1160 for 400 flights
It would be very expensive to buy these batteries but I am reusing what I already have for Funtana 90.
So, excluding the battery, motor+esc cost me $500 or cost of a cheap 50cc with muffler.
I am flying the heavier GP PW Extra 300 with a DA50 engine which cost me $650 with the slimline muffler.
50%plane 06-08-2005 10:58 AM
This sounds pretty cool. I wish I had the money.
ghee-grose 06-08-2005 11:02 AM
Hey red_z06... what kind of charge sheet is that on your batteries? I'm curious as to the data you put on there. It might be beneficial to some of us. ;)
red_z06 06-08-2005 11:14 AM
Ghee:
It is just a chage log with 480 boxes of 30 columns x 16 rows. It also shows initial charge date. I'll be happy if the battery packs last until the last box is marked and if the capacity is good enough after that... well that is freebee.
1st pack has 90 charges
2nd 65
3rd 34 <- since April 2005
3 packs are chaged as shown at home ( in my driveway ) then they are field charged with 80ah car battery in a custom box with banana terminals. While it is being depleted, 1000w generator replenishes with its 12v outlet and another 12v 24a radioshack power supply plugged into 110v outlet for additional 2 astro 109 chargers.
This allows me to continuously charge 2 packs while I'm flying the 3rd.
After flying the 3rd home charged pack, there is a bit of delay 10-15min before I can fly the 4th flight ( 1st field charged )
I really need 4th pack to fly nonstop.
ghee-grose 06-08-2005 11:52 AM
Cool!!! by the way....that some MAJOR battery power you got there! [sm=thumbup.gif]
BoneDoc 06-08-2005 12:26 PM
Well,
My cost is this
Moki 2.1 200 dollars used, with muffler already
5% fuel 8 dollars
Not to mention if you CRASH!!!, that's a whole lot money in puffed up Lipo. I already totaled my Sig 3D mayhem due to no radio control at all (not dumb thumb).
red_z06 06-08-2005 12:32 PM
BoneDoc:
The comparison was only for a 90 sized bird. There is absolultely no way you can compare 50cc class gas to electric in cost.
BTW, I used OS BGX1 2.2 in my fisrt PW extra 300 and I used 2cases of wildcat 15% in one month with the cost of $120. I immidiatly swithed to DA50 and gas for the power and fuel cost reasons.
BoneDoc 06-08-2005 12:39 PM
If my LHS didn't sell fuel so cheap, I probably would have been on the DA bandwagon too :D.
Don't get me wrong, I "grew up" on electrics, and if money were no object, I'd do that instead.
red_z06 06-08-2005 04:02 PM
1 Attachment(s)
Another piece of hardware....
Jeti advance 90 ESC mounted with some cooling holes drilled.
50%plane 06-08-2005 08:17 PM
I don't have anything against electrics, but the DA50 looks better.:D
How much did you pay for the entire power system?(batteries,speed control,motor)
red_z06 06-08-2005 09:19 PM
Axi 5330/18 $250
Jeti advance 90 $250
Batt Packs $0 (from Funtana 90) They would be $480 each new x 2
50%plane 06-09-2005 05:20 AM
[X(][X(][X(][X(][X(][X(][X(]
WWWWOOOOOOWWWWW
$1460.00 in a power system.
If you have the money then spend it.
red_z06 06-09-2005 06:30 AM
Like I said, not for 1st attempt at electric conversion.
For those who are interested, Funtana 40 would be a good place to start.
Motor + ESC would run you $250 and the batt pack would run you another $200 which is like buying 10 gal of 20% fuel up front.
Just remember, as size goes up, the cost increases exponentially.
red_z06 06-09-2005 08:05 AM
1 Attachment(s)
After running to a local hardware store for a contour gauge...
3 1/8" CF spinner is from EspritModel. Their FG spinner is dirt cheap (relatively speaking). I think I should have gotten 3.5" CF Spinner.
I just need to mount UBEC, 2 Batt Packs according to CG and build batt boxes, build 2 series Ultra Dean wire sets, and mount receiver switch and it will be ready for maiden.
red_z06 06-09-2005 08:07 AM
For more efficient heat removal from the motor, I will have to build louvers to redirect inlet airflow from the cowl.
50%plane 06-09-2005 08:11 AM
ORIGINAL: red_z06
That's what a dairy farmer told me a couple months ago.:D
drumbum 06-09-2005 05:50 PM
you forgot to mention the $390 for 3 astroflight 109s and the pyrimid power supply price;) and the $45,000 car in you avitar:D
red_z06 06-09-2005 08:10 PM
Don't waste your money on Pyramid Garbage power supply. It was rated for 40amps with 35amps continuous. When 18amps are loaded, it cuts out in less than 30min. When I called them, they said the duty cycle is 15min full, 45min idle. What bull**** @#$@#$.
So, it is good enough for 1 astro charger. You are better off getting Radio Shack 25amp switching power supply.
Drumbum:
You only need one Astro charger. I'm using 3 cause I want to fly it non stop. BTW, the Vette is actuall $53,000. It is a Z06 (405HP) not a regular vette.
drumbum 06-09-2005 08:48 PM
he he,, I thought we sold them cheaper than that. around $45,000 i thought.
red_z06 06-10-2005 11:00 PM
Does anybody find this thread useful or am I wasting my time?
red_z06 06-10-2005 11:04 PM
1 Attachment(s)
Motor, Spinner, 20x13 APC Eprop, Esprit Alu Mount, and 3 1/8" CF spinner all weigh 2lb 2oz
