What engine for the Diablotin???
What engine should I use in my Diablotin ???
Any one?? The instructions call for a 60-70 and the manufacture say's it will hover with a OS46. I would really like to put a 4-stroke in it.
I just put one together with a Saito 91. With 2 elevator servos and the rudder servo in the tail it is still tail heavy.
I wouldnt use a smaller engine. If I was doing it again I would use the Saito 91 because I already had the engine but I would move the rudder servo forward in the fuse and use pull pull. Joe Brannon |
Did the cowl work, it's to short for the YS 91AC ?
The cowl is too small for the 91.
Joe |
A YS 63 should be killer if a 46FX can hover it.
Hacker B50 13S with 6.7 gearbox, 14 cells, and 18X10 APC "E" prop :)
Originally posted by gwright Hacker B50 13S with 6.7 gearbox, 14 cells, and 18X10 APC "E" prop :) I'm gonna fly my E3D this weekend , can't wait. :D |
I have a YS 91ac in my Diablotin FG and it has unlimited vertical at a little over 1/2 throttle and I didn't need any weight to balance.The cowl is a little too short but It can be made to work if you don't care if it is perfect.
Pat |
Diablotin
Originally posted by gwright Hacker B50 13S with 6.7 gearbox, 14 cells, and 18X10 APC "E" prop :) Or 5S3P Lipolys-- fly for 20 minutes! Andre |
Looks like the Saito 72 is what i'm gonna go with see that no one has the YS 63 in stock.
Thank you HHI , I got a YS61FZ on the way.
LEt us know how it goes... I've got a YS 63 on the way.
Originally posted by Welsh3D LEt us know how it goes... I've got a YS 63 on the way. |
Please Post Pictures of Construction of Stabalator
Can anyone post pictures of how the Flying Stab is supposed to go together? It seems to simple to attach them with 4 screws and glue a copper pipe in place.
:confused: |
which Diablotin do you have, I have 3 supers which is the very light one. I use os 46fx with es designes cf tunned muffler which weighs much less than stock muffler and increases power 25%. it hovers at 2/3 throttle
| All times are GMT -8. The time now is 08:54 AM. |
